automatic brake pedal
Discussion in '40- & 55-Series Tech' started by 65j40, May 15, 2003.
  1. 65j40
    65j40
    2
    Apr 13, 2003
    I am looking for a good option for a brake pedal for my fj40. Any idea what a good donor car would be. I am looking to do as little fab work as possible. I would prefer a wide pedal for use with an automatic. Thanks
  2. woody
    woody Internet Fireman Staff Member
    10,333
    Media:
    303
    1,089
    Jan 15, 2002
    Toquerville UT
    one easy option would be to simply remove the clutch pedal and arm entirely and weld on a larger/wider pedal onto the existing brake pedal. Probably can hit a junkyard and find a pedal sized to what you want, cut it off, remove the pad, drill a hole-two to plug weld it on, grind clean, and replace the pad.
    :banana:
