Auto choke for webers
Discussion in '40- & 55-Series Tech' started by Cruiserhead05, Sep 14, 2003.
  1. Cruiserhead05
    Cruiserhead05 SILVER Star
    3,464
    10
    Jun 25, 2003
    Marshall, VA
    I have a 32/36 weber on my 2F. when installed the mechanic ran the auto choke wire into the harness and hooked it up to some misterious wire. i've never been able to see if it really works right. how can i test this. based on my start ups i dont think it is working right...even on cold morning i cant feel or a hear a choke working. no high idles or anything
  2. Ethan
    Ethan
    95
    May 15, 2003
    Northern California
    On my web I hooked up the wire to the +side of the bat to see what it would do. It took a little while but with the filter off you could see the buttersflys slowly open up. so in your case I would take off the filter start the motor and then watch it and see if it opens up. if not then it isnt working. or you could see if your getting a positive voltage off that wire when the cruiser is on. If you do then it should be working.
  3. 73lndcrsr
    73lndcrsr SILVER Star
    744
    4
    May 28, 2002
    If it is working, the butterfly will be closed when the temp is cool out and you are getting voltage to it. As the heat builds, the butterfly will open. I don't recall hearing the choke on my Weber, but I sure hear it on the Mikuni I have on my MG. BTW if the fast idle is not set properly, you won't have that either. I suggest getting the Haynes Weber book, it is very helpful.
