- Thread starter
- #61
thats what one of the mechanics said "bad pickup coil" so i replaced the distributor.....no spark....unless the distributor i replaced it with was bad. the engineer in japan said always get a new distributor.......so i am waiting on a new one........i will let you all know what happened......The tach is fed from the igniter. It's all 1 system. The FSM tells you what resistance you should see across the distributor pick up coils. You can make those tests right on the ECU connector or on the distributor connector. If you have a bad pick up coil, the ECU will shut the system down.
