Yes
Almost very RTT manufacturer sells ladder extensions, so not a probelm. I say do it!Great thread here.
I have a supersized FJ55 that I am thinking of adding a roof rack.
Mainly for the aux lights and coolness factor but I wondered how hard it will be to use a RTT.
Truck roof is 80" and I'm on 37's.
Will the RTT ladder even reach the ground?? LoL
Well, that didn't go as planned.The OP (lumbee1)has been very quiet since pulling the pin on this grenade......what are your thoughts and what will you go with? Without understanding exactly what your intended journeys are we are all scratching around basically putting our own 2c in. If you intend to go truly overlanding then many of the options put forward are just not available outside of the States.....
Well since we are reviving this zombie I'm with @SWCruiser on this one. If I were doing it over again I wouldn't go any bigger than a 285. My bias is due to the fact that I have both. My 97 has 315's and roughly 3 inches of lift. My 94 has 285's and roughley 1 inch of lift. The 94 gets around so much better. It's easy to get used to something like I did when I just drove the 97. However, when you have two of them to compare it really makes you think about what you like and dislike.
What are your thoughts on a 94' with 285's but going for a 2.5" lift? Currently I have the 285's (KO2) but worn out stock springs and OME stock height shocks (not worn out yet). I've been looking at the Dobinson's 2.5" level lift kit for my uses (mostly overland type travel, mixed with medium difficulty 4x4 trails).
Zack, you asked @half k cruiser, but if you don't mind another input, my '94 is almost identical to yours. I've got less miles - aprox 278K. On a trip to Canyonlands back in 2004, before my RTT, I realized, on the trail, my stock suspension was inadequate for my fully loaded-for-camping rig with stock Open Country M/Ts on a 2nd set of wagon wheels - this was at top of the Flint Trail, before descending:What are your thoughts on a 94' with 285's but going for a 2.5" lift? Currently I have the 285's (KO2) but worn out stock springs and OME stock height shocks (not worn out yet). I've been looking at the Dobinson's 2.5" level lift kit for my uses (mostly overland type travel, mixed with medium difficulty 4x4 trails).
Yeah, I read that the stock R & P gears were good for the 6BT with 35s, and that, IMHO, would be an excellent engine for overlanding. Although, I would run with the rear anti-sway bar, especially with the RTT. That's an awesome roof rack, is it a Prinsu?I run 38's.
They are too much for something that is just used for a DD and a bit of "overlanding" on pavement and gravel roads off the beaten path, but still on beaten paths.
My COG is less than perfect with the roof tent, its on road manors with tall tires, no rear sway bars and airbags are not what a 2.5" lift and 33's would be on every other 80.
But... The diffs are stock 4.11's and with a low revving engine the 38's are better for rpm's on the highway. To me these are about the right size for this particular truck.
I do use it in scenarios where I really am using all that 38's have to offer and don't DD it, I wouldn't/won't go to a smaller tire, but wouldn't necessarily recommend them for a coil sprung overlander/expedition purposed truck. I need to take more pictures of this thing, I've posted the same in other threads, but to show they don't seem ridiculously overkill
