ARB & winch and return to centre
Discussion in '80-Series Tech' started by MTNRAT, Apr 9, 2003.
  1. MTNRAT
    MTNRAT
    1,181
    18
    Mar 27, 2003
    Fernie B.C.
    I just installed a m12000 into my ARB bumper. I find that while driving the steering has gotten a little "heavier" with more return to centre. I have the castor correction bushings. I was wondering if the extra weight of the winch has pushed my front end down enough so that I no longer need the castor correction? Any fixes? Stiffer springs? Spacers?
    Regards,
    Sean
  2. Hltoppr
    Hltoppr SILVER Star
    2,024
    Media:
    4
    5
    Aug 29, 2002
    Port of Indecision...otherwise Northern Arizona
    In some instances, the addition of a winch/bumper combo has been known to negate the need for the caster bushings. This seems to be personal preference, although, and many well-respected shops (eg. Slee Offroad) will always use the caster bushings. It might depend on what front springs you are running? Since you have the bushings, I'm assuming that you have upgraded springs? What type and part number? A little more info could be helpful.
    -H-
  3. MTNRAT
    MTNRAT
    1,181
    18
    Mar 27, 2003
    Fernie B.C.
    I have the spring and shock upgrade from offroad australia. It gave me 2 1/2" lift on the front and little more than 3" on the rear. That was when I first installed them. Their website is www.offroad4x4.com.au/ . They only have one spring ratiing available for a late model 80. The part # is CS TYT-002. For what thats worth.
    Sean
  4. Hltoppr
    Hltoppr SILVER Star
    2,024
    Media:
    4
    5
    Aug 29, 2002
    Ok, then what I said before applies.  There's a good write up on the www.lcool.org website too in the Technical section.
    -H-
  5. bjowett
    bjowett Supporting Vendor
    3,051
    544
    Oct 28, 2002
    Western Massachusetts
    If you look at the very bottom of the picture, you can see my fix. The old IFS camber bolts (almost perfect in every dimension) with offset washers allow easy caster adjustment. It does require welding.
    [​IMG]
  6. MTNRAT
    MTNRAT
    1,181
    18
    Mar 27, 2003
    Fernie B.C.
    Thanks guys. It seems I am already getting used to the difference in steering. BTW I am going to show up for Cruise Moab, so I am sure I will get some input there, as people can actually look at my setup. I just hope a rock neophyte like myself will not be drug over the rocks :D.
    Sean
