ARB Air Lockers for an 80?
Discussion in '80-Series Tech' started by dsjackson, Aug 19, 2003.
  1. dsjackson
    dsjackson
    11
    May 26, 2003
    I have a 93 TLC that I originally bought for hauling the kids around, camping and towing our boat. We have gotten into the habit of some serious 4wheeling around Arizona and CO. Several times we have been beaten by a trail due to lack of traction. I have added a Slee Rear Bumper with Tire Carrier, Slee Transfer Case Skid Plate, Slee Rock Sliders, ARB Front Bumper with a Warn M12000 Winch, Garvin ¾ Wilderness Roof Rack, OME 2.5” Heavy Duty Suspension Lift, and 33” BFG MT Radials.
    I am now regretting that I did not hold out for a cruiser with Lockers. I am considering ARB Air Lockers. Does anybody have an opinion on their performance and durability?
  2. Junk
    Junk
    6,185
    23
    Dec 13, 2002
    buggerville nj
    They suck but are the only real option at this point. Either that, or buy another cruiser, swap the axles and sell the cruiser without the lockers. Just don't F up like one weenie in TX and do it with the wrong year. :eek: :flipoff2:
  3. sleeoffroad
    sleeoffroad Supporting Vendor
    6,056
    531
    Mar 27, 2003
    Ah come on Junk. Not all suck, just the ones in your truck :D
    Junk has had some problems but they are out of the norm (did you ever check your pressure in your air system?).
    We have installed them in a number of trucks and all work great. Yes, if installed incorrectly, they will leak. If the airlines are run wrong it will melt. If the compressor is installed incorrectly it will get trashed or stop working.
    I have wheeled with both, and I can say that I preffer the ARB's due to faster disengagement. Especially the front.
    Also the ARB carrier in the front is stronger than the E-lockers.
  4. Cruiserdrew
    Cruiserdrew SILVER Star
    13,593
    1,519
    Mar 15, 2003
    Sacramento, CA
    I have them in 2 of my TLC's-they work great. I had to have the rear resealed on my fj40 immediately after install, but since then they have been great. I have also used the stainless lines, but after having to re-run one of the lines after an engine fire, I prefer the standard blue plastic airline because it is much easier to work with. In fact, a good idea I cannot take credit for is to run the blue plastic line inside some fuel line to protect it. Route the lines carefully to avoid pinch spots and rubbing on the suspension. I ran the lines down the flexible brake line to the axle and this seems to work very well. Highly reccomended product.
  5. WolfpackTLC
    WolfpackTLC
    250
    Aug 4, 2003
    Central NC
    Don't listen to that Christo guy, what does he know.... :D
    Just kidding. I've recently acquired a rig from that very Christo guy, and it's ARB'd F/R and they are phenomenal. I much prefer them and their quick disengagement to an e-locker any day. Driveability over a standard locking diff? Please... ARB hands down.
    J
  6. Junk
    Junk
    6,185
    23
    Dec 13, 2002
    buggerville nj
    Probably true. :flipoff2:
    No. :-X
    As far as options, I still think the elockers are the best choice. You can force them to stay locked if there's a problem right? Not so with the ARB's. All I know is that with all the problems mine have had, there is no way I would ever put them into another rig. Maybe that's why a lot of mofos on POR prefer not to use them? :p I have had too many issues with them to just sit back and say it's due to bad install. Sometimes even the stuff is failing on the first use after reinstall. Oh, and ARB has never warranteed anything!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! ... even after using my beater for their add, they provided no warrantee!!!!!!!!!!!!!!!!!!!!!!!!!!
    I'm not surprised Christo's shop has had no problems. Those guys can make anything work effectively. In my opinion, it is not a finished product design. Too many flaws and weak links. They simply figured it was good enough to sell and don't bother to look at the problems.
  7. sleeoffroad
    6,056
    531
    Mar 27, 2003
    [quote author=Junk link=board=2;threadid=4432;start=msg33209#msg33209 date=1061308640]
    [/quote]
    That is all true, however we have seen some failure of actuators lately. Some that can not be repaired. It then becomes pretty costly.
    [/quote]
    I have seen a lot of people bitch about them, then when you ask them what went wrong, they say the lines melted, or a variety of issues that was install related.
    [/quote]
    That is really a shop issue and not an ARB issue. Yes they are tricky to install, and yes sometime we are going to have comeback as well, however ARB has always stood behind us when we wanted something waranteed. However they will not warrantee abuse. Not saying that you abused it, you would never do that ::)
    [/quote]
    Did you get the pressure guage on your system? I am still interested to know what went wrong with your system.
    [/quote]
    I think we avoid some of the issues by using the Toyota switches etc etc, however it does cost the client a lot more money than slapping in the harness and then just hooking up the switches. I know you had some issues with the switches, but that type switch is a pretty common switch used in the automotive market. As for the rest of the pieces, the are pretty well made. The did have some issues with internal oil seals that has now been changed over to a new style.
    If you can buy a truck with factory lockers, yes, you are ahead of the game. If you can buy a wrecked truck with lockers and swap diffs, you are ahead as well, depending on how the $'s work out and if you can dump the other truck. However that is a lot of work.
    ARB's are by far the best non-oem choice for trucks where you don't want ANY effects from the locker on the road. That said, if you are a POR dude and run big ass tires etc etc and are heavy into rock crawling etc etc, I can see why you would run a Detroit. No fuss, no mess, just run it.
  8. BMT
    BMT
    325
    Apr 1, 2003
    There was a thread a few months back on putting factory lockers in a cruiser that did not come with them. You can do the front and rear at different times if $$$ does not allow an all at once install. Another option is the used axle route. I think it is cruiserparts.com has locker equipped axles. Rear $1,000.00 and front $1,500.00. A few guys on the board have done it. As soon as I can get my wife to stop doing things like having french doors installed I too will put in factory lockers.
  9. Hltoppr
    Hltoppr SILVER Star
    2,020
    Media:
    4
    3
    Aug 29, 2002
    Port of Indecision...otherwise Northern Arizona
    BMT,
    It's easier to get forgiveness than permission.... just get the axles, she won't even notice...
    -H-
  10. landtank
    landtank SILVER Star
    18,416
    594
    Mar 27, 2003
    Groveland MA
    BMT,
    Get the axles and get them installed under the cloak of darkness. Then paint the old ones up real nice, put a bow on them with a card that reads " A nothing special reason gift for a very special wife". When she asks what they are with a big smile you reply "Bird Houses".
  11. dsjackson
    dsjackson
    11
    May 26, 2003
    Based on the advice and products that I have received from Christo, if he says ARB Lockers are ok, I’m sold. I just wish Slee were not a 14 hr drive each way so I could have them install them as that seems the tricky part. Do you have any good suggestions of a shop in Phoenix that might do a good job?
  12. Big_Moose
    Big_Moose
    426
    Aug 26, 2002
    Dsjackson
    I will have to agree with all the others that ARB's are an awesome locker! I have been running them in my '40 for the past 12 years. They have performed flawlessly even with the air seal retaining, allen head bolts vibrated loose about 9 years or so ago. I also installed my own ARB's in the diffs, really not that difficult.
    Christo doesn't need the truck to install the ARB's. Remove the differentials and send them to him for installation. During this downtime, you can complete the front axle rebuild if necessary, since you are in there anyway.
    I think Junkster is jinxed when using ARB products.
    Joe
  13. LINUS
    LINUS Waiting for the Great Pumpkin
    2,055
    Media:
    2
    381
    Mar 29, 2003
    PNW - WA
    I was in the same place as you, and I chose to go factory lockers for the reason that doing my own install it's going to be cheaper than to go ARB. My way of thinking is that factory parts will be easier to work with in the long term if I wear something out or the like. My main use is for snow traction when I go to the local mountain snowboarding. I have a fairly realistic view that if I get into wheeling too much that I'll probably just buy a 40 for off-road and keep the longer wheelbase 80 for street / light stuff / snow.
    On that note, my locker package is still sitting in the garage waiting for install. :mad: Once I finish painting the house the lockers go in.
  14. Junk
    Junk
    6,185
    23
    Dec 13, 2002
    buggerville nj
    Dang Linus - you should have checked first. Someoneon this forum may have some extra actuators. ;) :flipoff2: :D
  15. BMT
    BMT
    325
    Apr 1, 2003
    dsjackson...born and raised in Phoenix. The shop that has been around the longest and does everything from mild to wild is 4Wheelers Supply & Off Road on Washington. Check out the shop. Another one that might be O.K. is Off Road Unlimited but I'm not 100% on that one. It is the old Republic Offroad and I had a few friends that worked there. They do quite a bit with rock crawlers. I would stay away from any of the chain stores. We don't drive a Ford, Chevy, Dodge or Jeep. Hope to run into you sometime.
  16. BMT
    BMT
    325
    Apr 1, 2003
    landtank & Hltoppr...good advice but she has spent all my money!!! The only thing I could do is sell something. Hmmmmmmm...lets see...For Sale...one wife...barely used...comes with 2000 Chevy truck and a cat...please call. :D
  17. landtank
    18,416
    594
    Mar 27, 2003
    Groveland MA
    No offence BMT, will you part out the cat? :D
  18. dsjackson
    dsjackson
    11
    May 26, 2003
    BMT,
    Thanks for the information. I think I will swing by and talk to Off Road Unlimited. They did the install of my ARB Front Bumper, winch and OME.
  19. cruiserdan
    cruiserdan SupportingVendor Emeritus Supporting Vendor Moderator
    20,603
    2,978
    Mar 27, 2003
    Surrounded by Cruisers from all over the world
    I retro-fitted OEM electric locks to my 80. I modified the original rear housing to accept the locker diff and used a new front housing for a lock equipped vehicle. The main reason I did it was to see if it could be done. In addition, I "knew someone" to get the reqired stuff from ;) . I spent a bit more than I would have to get ARB's but I have not looked back. If anyone is GENUINELY interested in the conversion, I would be glad to share my Knowledge regarding said project. I will warn interested parties up front that this IS NOT CHEAP if you do not have a donor vehicle. If you choose to utilize a new front housing, parts will push 4 grand. So, if you have to ask how much it is, you can't afford it. ;)
  20. Rogue
    Rogue
    968
    1
    Mar 27, 2003
    Jefferson
    Hey Dan,
    How much is it? :p
