Anybody need "Electric Locker Actuator"
Discussion in '80-Series Tech' started by Animal, May 22, 2003.
  1. Animal
    Animal
    63
    Mar 27, 2003
    North Pole, Alaska
  2. Rogue
    Rogue
    968
    1
    Mar 27, 2003
    Jefferson
    That is a beauty and currently going for over $500 off of list price.
  3. landtoy80
    landtoy80
    5,668
    241
    Mar 13, 2003
    North Front Range, CO
    Thats the part I need. All I need is the housing. Anyone have a bad one they want to get rid of. Or if you need the guts, we can split the difference.
    kurt
  4. cruiserdan
    cruiserdan SupportingVendor Emeritus Supporting Vendor Moderator
    20,605
    2,983
    Mar 27, 2003
    Surrounded by Cruisers from all over the world
    Kurt,
    The guy on ebay has one ::)
    Why don't you bid on it? :dunno:
  5. landtoy80
    landtoy80
    5,668
    241
    Mar 13, 2003
    I ordered the cable locker from Downey. I haven't got it yet. They were working on it when I called and told them to send me one when the get them in.
    kurt
  6. cruiserdan
    20,605
    2,983
    Mar 27, 2003
    How much do they want for the cable locker that they can't seem to get for you?
  7. landtoy80
    landtoy80
    5,668
    241
    Mar 13, 2003
  8. cruiserdan
    20,605
    2,983
    Mar 27, 2003
    OK, so the one on ebay is up to I think 255 bucks. So, for 150 bucks more than you already need to spend you can fix it right. It's still a helluva lot cheaper than visiting a dealer, even a nice one ::)
    BTW In the pictures, it appears that it may have been installed at one time. It does look new however.
  9. Junk
    Junk
    6,185
    23
    Dec 13, 2002
    buggerville nj
    So Dan - now that the auction is over - what's involved in retrofitting an elocker into a non OEM locked diff?  Can it be used with other gears (4.56, 4.88 )?  Since my portals are stalling, I may just want to go another route and go to elockers since my ARB's have taken a few years off me life.
  10. cruiserdan
    20,605
    2,983
    Mar 27, 2003
    Junk-ola,
    A factory locker for the rear is quite easy. You will need a third member, RH axle shaft, Difflock ECU, switch, indicator bulbs, wiring harness from diff to LH rear quarter, some longer studs, a couple of gaskets, actuator protector plate and you will need to build a 14 foot long harness that travels up to the LH kick panel. The front is a bit more challenging. You will need a diff, wiring harness,some longer studs and you will either need an axle housing or you will need to heavily modify the existing housing where the diff mounts up. It has been done(by me) and it looks like a duck and quacks like a duck.
    I did it with a new front housing and I modified the rear housing. Other than stock gear sets will work. You will need to have locker third member housings though. It is not possible to morf the standard pumpkins.  If you wish more details PM me and I will bore you with them.
      Cheers, Dan :beer:
    Oh, Kurt. It went for 360 bucks. You missed out there. :stupid:
