Another check engine light ?!!!!
Discussion in '80-Series Tech' started by TrpD345, Jul 9, 2003.
  1. TrpD345
    TrpD345
    13
    Jun 10, 2003
    If you take a paper clip and jump between the two pins on a '94, what will the light do if it was not on? Mine was coming on and it was a code 71. The dealer said that they found a hose that was coming out from under the egr valve that was dry rotted. They replaced it and it has not came back on since. I was just wanting to make sure they have not pulled one over on me! I put the paper clip in it today, the check engine light was not on, and turned the switch on. The check engine light light just blinked steady, no pauses at all like when it was showing 71. Is this normal? Thanks!
  2. cruiserdan
    cruiserdan SupportingVendor Emeritus Supporting Vendor Moderator
    20,564
    2,891
    Mar 27, 2003
    Surrounded by Cruisers from all over the world
    I suppose you shorted T1 and TE1?
    The no-code-stored pattern is steady blinking with no variation in time duration between blinks. (My, that was a redundant statement, wasn't it ::) )
    So, yes, it is normal. (unlike some of us 8) )
  3. TrpD345
    TrpD345
    13
    Jun 10, 2003
    Thanks CruiserDan!!!!!!!
