Amp Speaker
Discussion in '80-Series Tech' started by landtoy80, Aug 2, 2003.
  1. landtoy80
    landtoy80
    5,668
    241
    Mar 13, 2003
    North Front Range, CO
    Does the right rear quarter pannel speaker and I think its an amp, have any use with an aftermarket stero?
    Or should I can it and make the 80 lighter ;)
    kurt
  2. Jon916996748
    Jon916996748
    144
    Jun 10, 2003
    Columbia, SC
    If you hooked up your new stero with the two plugs that weren't attached to the OEM one then it should have nothing to do with it. Of course your going to have to disconnect the amp from the truck and the speakers I think. Not 100% sure though. Try it and see :D.
  3. - S.A. -
    - S.A. -
    350
    1
    Mar 27, 2003
    JERSEY
    I actually found on the internet..some guy who basically replaced the factory sub amp/speaker w/and aftermarket amp and a modified speaker box. It looked like one of those pre-built subwoofers called megaform..or something like that. If i recall i think he bought a rear pre made Megaform (?) enclosed sub for a ford explorer and modified it to fit where the stock sub is in the LC. (they are available in Crutchfield)
    I was thinking about doing that someday..just havent gotten around to it.
    later..
    -Joe M.-
  4. cary
    cary
    3,109
    21
    May 7, 2003
    Joe M,
    Do you have the website? I would love to see the install.
    Thanks
    Cary
  5. Jon916996748
    Jon916996748
    144
    Jun 10, 2003
    Columbia, SC
    Don't know if this helps, but this is Robin Hood's.
  6. landtoy80
    landtoy80
    5,668
    241
    Mar 13, 2003
    Is there a cover that goes over that? Between me and the kid, the speaker and amp would be destroyed.
    kurt
  7. - S.A. -
    - S.A. -
    350
    1
    Mar 27, 2003
    JERSEY
    I am sorry..i dont have the websight. I came across it about a year ago while doing some general stereo searches on the internet. The pic above is basically the same concept as the one i saw..except, this guy used the stock panel to cover up his sub. Only modification was that he replaced the small stock speaker grille w/a bigger one. I will search around..and if i can find it i will post.
    -Joe M. -
  8. Jon916996748
    Jon916996748
    144
    Jun 10, 2003
    Columbia, SC
    You can get mesh guards that just use the same screws that you use to screw the sub in. As for the Amp, you could mount it somewhere else, under the drivers seat for example.
