I have been chasing down a runability issue with a stock, fully IM compliant 1980 2F.
Up at higher RPM, when the engine is accelerating under load, about 30-40 MPH, say about the shift point 3rd to 4th. the engine starts bucking & hesitating. took the rig to a shop that focuses exclusively on 60's-70's carb'ed engines. spends most his time on hot rods & Detroit restorations. The technician cleaned up vacuum lines, and it helped a little. The technician stated that with a vacuum pump, could only get the distributor to advance 7* but would like to see about 15*.
I doubt he has a Toyota FSM. Probably shooting for 15* as a rule-of-thumb
A couple of questions for the forum:
Do these runability symptoms sound like a distributor advance issue?
Does it sound like this distributor needs to be replaced?
If the answers to the above are yes yes. If I go with HEI replacement, will this violate the IM laws of most states? Do I need to go with a straight OEM or exact aftermarket replacement?
