Aluminum Radiator vs. Stock Radiator
Discussion in '40- & 55-Series Tech' started by SuperDuperCruizer, Aug 20, 2003.
  1. SuperDuperCruizer
    SuperDuperCruizer
    416
    Media:
    9
    28
    Jun 24, 2003
    Takoma Park, MD
    Are the Aluminum radiators better than stock? Just wanted your thoughts on the issue. Thanks, SuperDuperCruiser
  2. Texican
    Texican s-Moderator
    5,814
    Media:
    175
    91
    Dec 17, 2002
    Bonham Tx.
    If you have a V8 yes they are the ticket, I have a Be Cool in mine love it temps at BHCC in 102 degree weather stayed around the 195 thermostat I have in it.
    Butch
  3. toddslater
    toddslater SILVER Star
    1,498
    2
    Oct 31, 2002
    Kennett Square
    Aluminum will dissapate heat better/faster than conventional. But unless your running something very robust, it may not be worth the effort/expense. Simply resizing, going to a cross flow, and/or adding a baffle, going to a 4 core should be plenty good enough for any motor you can fit into a cruizer.
  4. joefj
    joefj
    249
    Aug 9, 2005
    sykesville,md
    I have a sbc in my 40 and could not cool it w/ a 4 core fj radiator. Bought a Jegs 19x26" aluminum unit, no more problems, actually runs too cool and need to change my thermostat and only $200.
    Summer temps here in Maryland get in the 90 degree range and the 4 core would climb to 220, the aluminum has never hit 190.
  5. joefj
    joefj
    249
    Aug 9, 2005
    sykesville,md
  6. my64fj40
    my64fj40
    1,646
    2
    Aug 6, 2005
    Corpus Christi/Austin, Texas
    If your running a say 400 SBC yes it's better.
    I went with a Griffin 19x31 generic aluminum radiator from Summit for a very reasonable price.
  7. iokepa
    iokepa
    20
    Mar 9, 2006
    19x31? How did you fit that in there? Can I see some pics? I am trying to get some ideas on fitting somthing bigger than the stock rad in my 69. It has a 383 and runs too hot (about 220 when it's 100 outside) with the stock rad tanks + 4 row core.
  8. MTDewX8
    MTDewX8
    223
    Mar 25, 2010
    Montana
    so the folks that have a 350, what do you use for a temp gauge? stock, or is it a good idea to get another one to make sure what the temps are.
    I am still learning what I have. and the PO said he has no problems with heat, but my question is how do you know if your only using the stock gauge.
    assuming the kits are not to bad to install
  9. xjnation
    xjnation
    605
    4
    Jul 13, 2005
    Springfield, MO
    I got one of the aluminum 40 radiators from Ebay for around $200 shipped. It was a bit thicker than stock and took a bit of clearancing in the radiator support, but the truck doesn't get over 185* with a 4.3 vortec. It ran about 200*ish with the stock radiator.
