alternator conversion
Discussion in '40- & 55-Series Tech' started by 74cruiserintexas, Dec 24, 2002.
  1. 74cruiserintexas
    74cruiserintexas
    37
    Dec 24, 2002
    I have a cruiser built in Nov 1974. I would like to find an alternator with a higher amp rating. Has anyone found an alternator that will work or can the existing alternator be fixed for more output by an alternator shop? Any input would be greatly appreciated. By the way it is completely stock.
  2. Mavric1298
    Mavric1298
    163
    Oct 28, 2002
    I would look into getting a "mean green" alt. I know their starters are really good, so i assume their alt are too
  3. woody
    woody Internet Fireman Staff Member
    10,333
    Media:
    303
    1,090
    Jan 15, 2002
    Toquerville UT
    Mean Green is an option, there are many Chevy alternators that kick out 105+ amps, and custom wound alternators are an option too. Cheapest will be the Chevy....custom next, then the mean green. Only bad about custom is warranty....(usually none...heh)
  4. Gumby
    Gumby Supamod Staff Member s-Moderator
    11,778
    308
    Dec 13, 2002
    Knee deep in hookers and gin
    Slappin in a GM alternator is easy and removes the problems of a mechanical voltage regulator. I like cheap and easy and better.
  5. Gumby
    11,778
    308
    Dec 13, 2002
    I was looking through my TTs to answer another question and I saw an article in the 3/4-2000 issue on installing a 108A GM big case alternator. It was pretty good in that it addressed a lot of little problems. i can scan and send it to you if you'd like.
  6. 74cruiserintexas
    74cruiserintexas
    37
    Dec 24, 2002
    Gumby..that would be great if you could scan it and e-mail it to me. I am curious as to the things needed to be changed. Thanks a million...
  7. PF
    PF
    104
    1
    Dec 26, 2002
    Corona, CA
    I was thinking about doing the same to my FJ62. Can someone tell me if I can put Chevy alternator on my FJ62? Would there be issues with the ECU?
  8. 74cruiserintexas
    74cruiserintexas
    37
    Dec 24, 2002
    UPDATE!!!
    Well I went to O'Reiley Auto parts and they had an 100 amp Delco alternator that had the same mounts as the factory Alternator. All I had to do was narrow the factory alternator bracket on moter by 1/4 inch and everything lined up perfect. I also had to buy a chrome chevy Alternator top bracket because the original straight one would not clear the new alternator. It was a very easy conversion and well worth it because now I have around 45 or so amps at idle and 100 or so at around 3000 rpm.
  9. verdeolivo
    verdeolivo
    33
    Sep 24, 2008
    Do anybody knows for what is the Pump in the rear of my 1978 TLC alternator? once i leave a hose not enouh tight and it become to spur motor oil from it when i started the engine so i think is my mechanical oil pump,right?
  10. Martian
    Martian
    200
    Aug 27, 2006
    Annapolis, MD
    How do you deal with the GM alternator having a narrower pulley than the stock? Do you replace all the other pulleys to have the same width ? The PO of my rig put in a GM alternator with a narrower belt, but didn't change the other pulleys. Went through belts pretty quickly, lots of squealing, etc. I ended up putting a Toyota OEM alternator back on.
  11. bsevans
    bsevans Focus on the Journey
    2,009
    Media:
    50
    13
    Jun 9, 2005
    Southern Arizona
    I installed a mean green alternator that came with a double pulley that fits the factory width belts. It has been installed for a number of years and has never faltered. It has a 200 amp rating. I had to make a spacer which was no big deal.
  12. dargreg
    dargreg
    626
    Media:
    1
    Jan 10, 2009
    CROFTON BC CANADA
    That should be a vacumn pump if you are running a 3B.
  13. bsmith123
    bsmith123
    3,080
    2
    Oct 9, 2007
    Norfolk United Kingdom
    amps
    How are you measuring the AMPS or is that just the rating?
    It would not be ideal to be constantly flowing 100 amps---what's pulling it?
  14. Gumby
    11,778
    308
    Dec 13, 2002
    The author of the article in TT suggests using a 17/32x53 belt to split the difference between the toyota and GM pulleys. I can't remember what I did. That was 10 cruisers ago.
  15. zebrabeefj40
    zebrabeefj40
    3,190
    29
    Feb 19, 2004
    Pepperell MA
    I have used the OEM pulley on a GM alternator with success in the past...
    Nick
