Folks,
I replaced the steering rack a few weeks back and took it in to be aligned. The tech could not align the toe to spec on the passenger side as he maxed out on the adjustment.
There is plenty of adjustment available on the driver side.
Can this be solved by just turning the steering wheel towards one side and then adjusting the tie rods on both sides to get a 'new center'. I can then pop of the steering wheel and put if back centered properly? Or do I have to disconnect the steering column from the rack, then center the steering rack and reattach to steering column? Is the 'lock to lock' movement physically limited bu the steering rack or is there something in the steering column that limits it?
