Aisin Hub question..
Discussion in '40- & 55-Series Tech' started by DenCo40, Feb 19, 2013.
  1. DenCo40
    DenCo40 Cruiser Snob
    261
    1
    Jan 16, 2010
    I have a set of Aisin locking hubs I would like to install on my 77 Fj40. The hubs are from an 86 fj60. I understand I have 27 spline birfs and the Aisin hubs are 30 spline. Can these be converted by purchasing longfield inner hub gears? I know I can just buy the 30 spline birfs $$$ and be done with it but I'm not interested in that just yet. OR to make it simple can I just bolt these things on to my 40?
  2. pardion
    pardion SILVER Star
    2,480
    111
    Nov 5, 2005
    Camino, California
    Count your outer splines again, you should have the same count as the aisin's, the problem that may come up is your birfields on a 77 are 3/8" longer than a n FJ60, you can change to mini or 1979 and newer birf's, they will have 27 spline inner which your current inner axles will work with. HTH John
  3. Fast Eddy
    Fast Eddy SILVER Star
    14,094
    1,493
    Apr 5, 2006
    Morgan Hill, CA
    Those hubs are too short to fit over your birfs, as pardion points out. Your hubs are the ones on the far right. The correct hubs are the ones just to the left of those.
    Tech thread here: http://forum.ih8mud.com/40-55-series-tech/211679-locking-hub-interchange.html
    [​IMG]
    You need different hubs or a bunch of different parts on your front end.
    They are rare, but they show up once in a while. I have a set on my '78.
    [​IMG]
  4. DenCo40
    261
    1
    Jan 16, 2010
    "Those hubs are too short to fit over your birfs, as pardion points out. Your hubs are the ones on the far right. The correct hubs are the ones just to the left of those.
    Tech thread here: http://forum.ih8mud.com/40-55-series...terchange.html"
    I didn't see that thread in my search...
    So you are saying that 55 series Aisin hubs are direct bolt on? Will mini truck or late model birfs work with the short hub? I read a couple of threads about people cutting the long ones down.
  5. DenCo40
    261
    1
    Jan 16, 2010
    Would these do the trick?
    http://forum.ih8mud.com/sale-parts/692067-profield-birfields-new-portland.html
  6. Fast Eddy
    14,094
    1,493
    Apr 5, 2006
    Morgan Hill, CA
    It's not just the birfs. The knuckles are different and have a different pattern for the steering arms, so the steering arms are different.
    His package deal has some of the parts you need:
    http://forum.ih8mud.com/sale-parts/695469-upgrade-your-knuckles-birfs-package-deal.html#post8297898
    But then you need to get some new steering arms rebuild your knuckles (bearing/seal kit). To do that you'll need a knuckle centering SST.
    See how we're cascading here? What's wrong with the freewheeling hubs you have now?
  7. DenCo40
    261
    1
    Jan 16, 2010
    40's have a cascading effect as it is. I was just checking out just the birfs not the package. One of my warn hubs has a slight crack so I might as well upgrade while I can. I was just thinking swapping out the original birfs and swapping in something slightly better and the right size for the hubs I have..
  8. MOTOV8R
    MOTOV8R SILVER Star
    400
    26
    May 19, 2009
    Boise, ID
    All you need is newer birfs (79+) and a grinder to fit those hubs. You don't need the whole knuckle and steering arms. If you have those parts as well might be an opportunity to upgrade but not required for the hubs.
  9. cuencanolenny
    cuencanolenny
    844
    98
    Dec 18, 2012
    Cuenca, Ecuador
    Aisan Hubs
    Here in Cuenca, Ecuador I bought a 1970 FJ40. It failed inspection for steering, semi-functioning turn signals, only one windshield wiper (I think it only came with one and the vehicle is older than the inspector), leaking transmission, poor brakes. So some parts are being sourced here but I have 180 lbs of brakes, clutch, emblems, etc. coming down. Slow, expensive process but I save quite a bit of money buying them in the USA. This non-USA vehicle has the standard axles without free wheel hubs. I "thought" I would go with WARN, however, this site has many comments and pictures of exploded ones and so I went with Cruiser Corps for new 6 spline hubs. My question is this; "When I go to install these hubs are there any parts that I need for the change that will not come with the new hubs?
  10. Fast Eddy
    14,094
    1,493
    Apr 5, 2006
    Morgan Hill, CA
    Ask them.
  11. jstncse
    jstncse Crawling over something
    1,145
    Media:
    2
    103
    Dec 15, 2010
    Albuquerque
    DenCo40,
    I just installed aisin hubs on my 78. I took the original birfs and had a snap ring groove cut into it and then shortened 10mm, this worked perfectly and did not require any other replacement parts.
  12. PabloCruise
    PabloCruise SILVER Star
    14,997
    718
    Jun 3, 2004
    Northern Colorado
    I recognize that first picture...
    I like this one better, cause it shows the diaper name.
  13. MOTOV8R
    MOTOV8R SILVER Star
    400
    26
    May 19, 2009
    Boise, ID
    Here's another couple pics, which show the hub dials are slightly different as well.
  14. DenCo40
    261
    1
    Jan 16, 2010
    Thanks for the responses everyone. I'm going in! I picked up the Birfs from a guy here in the classifieds. Now I just need some decent weather since I'm rebuilding the knuckles at the same time. :wrench:
  15. PabloCruise
    14,997
    718
    Jun 3, 2004
    Northern Colorado
    Make sure you get a couple of rolls of paper towel!
    And the right types of grease...
  16. Fast Eddy
    14,094
    1,493
    Apr 5, 2006
    Morgan Hill, CA
    Disc brake grease for the spindles (red usually) and Moly grease for the birfs.
    I like newspaper instead of paper towels for the really dirty work.
  17. Tigerstripe40
    Tigerstripe40
    2,133
    109
    May 3, 2004
    Utardia
    You can use the earlier birfields with the shorter aisin hubs.
    The deal is, though, you have to have the inner Martacked and you will end up chewing up the end of the inner axle shaft. The axle will get chewed up pretty much from the groove where the circlip installs to the end of the shaft.
    I ran my truck this way for 5 years. Didn't have any problems.
  18. cuencanolenny
    cuencanolenny
    844
    98
    Dec 18, 2012
    Cuenca, Ecuador
    Thank you, Cruiser Corps did send an email, that I believe confused me with another customer, however, it directed me to MarlinCrawler where I found a number of pieces. My last of twelve packages will arrive today, clutch kit, took 67 days where in the past my experience has been 18-21 days. Apparently a new customs process is speeding things up. Note to all, the good folks at CoolCruisers of Texas say they have been told that March 2013 customs in the USA will also be slower. Don't know if that impacts any of you but it would be worth inquiring about if you were ordering something from Australia, Japan, Taiwan or Europe for your project.
