Ag tractor tires
Discussion in '70-Series Tech' started by lshobie, Apr 22, 2008.
  1. lshobie
    lshobie
    3,045
    Media:
    5
    10
    Feb 1, 2004
    Hi Guys,
    I am looking to run a set of tractor tires on my HZJ79, I'd like something 36-38 inches with a heavy ply rating. Anyone have any suggestions?? I use a 16 inch rim - widest I can get a 6.5 inches so it limits me - unless I cut and splice a band in. There is no other rim size that I can buy for it - unless I buy it in australia or switch to an 18 inch rim for the new tundra 5 bolt pattern - then tires are about 4-500 each.
    Suggestions?
    Louis
  2. nickwood48
    nickwood48
    69
    Oct 8, 2005
    How about some Non-dir military tires. Check out the 9.00-16, they are close to your specs at 35.5" tall and looks like a 6.5" rim should work.
    Non-Directional Military Tires - Specialty Tires of America
    I
  3. lynchmob
    lynchmob
    2,352
    39
    Mar 1, 2007
    Portland OR - USA
    crushers has a set on his "tractor" 70 series. I dont recall if they are on skinny rims though.
  4. matt 105
    matt 105
    433
    2
    Jul 10, 2006
    Bowen Basin, QLD Australia
    Tyres for rice crops are popular in mud racing here. They are availible for 16" split rims and measure 33"-35"(an 85 - 100 or more profile). Rice tyres are usually narrow with a 23' tractor type tread, with a wider than standard void between narrower lugs.
    Hope this helps.
    Matt
  5. lshobie
    lshobie
    3,045
    Media:
    5
    10
    Feb 1, 2004
    The michelin XZL's look good - they are military tires, 9.00-16LT's, 36 inches.
  6. matt 105
    matt 105
    433
    2
    Jul 10, 2006
    Not sure what you intend to do with them, but for an off-road only toy, they take a grooving iron well. This helps them lose some weight as well. They are designed for something a little heavier than a 70srs of course.
    sorry - thinking of XML here- an ASLAV uses a 325/85R16- a big, stiff, boot, designed for an armoured vehicle, that will hold the thing up if some wheel stations are removed- just to give you an idea of how stiff they are.
    They are not bullet proof- no matter what you read on here.
    Matt
  7. crushers
    crushers post ho SILVER Star
    22,190
    157
    Feb 10, 2004
    Tara Ontario
    i have watched the XL in action and wasn't impressed.
    i run a 36" tractor tire for off road use and have impressed many with it's performance, i also groove the treads for added traction...
    for strickly off road use they are real hard to beat. i will be running these next weekend at the local UC run...
    oh, and i run them on stock LC 16" rims
    cheers
  8. dslcruzr
    dslcruzr
    410
    Oct 7, 2006
    Victoria, BC, Canada
    I have some 11r16 XL's and I am fairly pleased with them. Long lasting, super tough and they dig like crazy. A little slidy on off camber situations. Siping would probably be a good idea, although I haven't yet.
  9. jasonmt
    jasonmt
    613
    Feb 6, 2007
    Edmonton/ Fort Mac.
    For the Goodyear/Titan AG tyres these are the first three that pop into my head:
    11.2-16 Dyna Torque II - 35.5" tall
    12.4-16 Sure Grip Traction - 36.9" tall
    12.5L-15 SL Sure Grip Traction - 33.3" tall
    Local SamToy running the 11.2-16 Dyna Torque II on 8" wheels:
