aftermarket/rebuilt 93 d-s birfield/cv-joint
Discussion in '80-Series Tech' started by semlin, Apr 1, 2003.
  1. semlin
    semlin rocker
    5,208
    Media:
    1
    324
    Mar 27, 2003
    north of 49
    Hi guys, the aftermarket 1993 d-s cv-joint/stubby axle I ordered had no abs sensor so I am back in the hunt for a used, rebuilt or aftermarket one. Any suggestions on a parts source? An OEM is 10 days away and $700CDN ($450US)
    As no 80's here in Canada this is not an item carried by any supplier and my local 4x4 shop has come up dry. I have shipped it to a driveline place to see if they can custom rebuild but if not, I will need a replacement.
  2. cruiserdan
    cruiserdan SupportingVendor Emeritus Supporting Vendor Moderator
    20,564
    2,891
    Mar 27, 2003
    Surrounded by Cruisers from all over the world
    Simon,
    Christo may have some at his place. you can use up to 97, but you may have to change the drive flange also as the spline length was changed late 93 or early 94. I don't remember exactly when and as I am not at work right now I can't look up the exact date of the change. The OEM ones supercede to the later, longer splined version and the new flange is required to complete the install. Go to his site and see what he has...LX450's use the same one, all of them being the newer, longer one.
    PM me if you like and I will be glad to assist further....
    Regards...Dan :beer:
  3. sleeoffroad
    sleeoffroad Supporting Vendor
    6,056
    531
    Mar 27, 2003
    Are you talking about the ABS ring on the birfield? If so, you have to swamp it our. It comes of the old one and you press it onto the new one.
    Christo
  4. erics_bruisers
    erics_bruisers
    2,032
    2
    Mar 28, 2003
    senlin, your avatar doesn't come up -- hp photo doesn't work for them.... :-[
  5. semlin
    semlin rocker
    5,208
    Media:
    1
    324
    Mar 27, 2003
    north of 49
    Christo, the replacement part had no machined surface to swap over the ring.
    thanks for all help. I have a guy trying to rebuild it now. If he fails, I will ship it to the Longfield guy in Washington state.
  6. landtoy80
    landtoy80
    5,668
    241
    Mar 13, 2003
    North Front Range, CO
