My '84 FJ60 with a stock 2F doesn't seem to have any way to tension the AC belt. It's passenger side, just below the power steering pump. I found a thread with some pics, but it did not match my set up. Anyone have any advice?
Yea I found that but how do you get enough tension on there? Just by hand? Is there a way to add more tension than whatever I can get just pulling on the compressor?
Ahh! 2FE is EFI. Nope. It's a regular 2F with a carb.Here the sweat beating heart. I'm not sure how to tell if it's 2F or 2FE. It definitely says 2F on the valve cover. It runs great with the desmog and current set up. The large tubing heads over to my snorkle which exists to look awesome.
Lol.. Definitely NOT stock. A 2FE is basically a modified 2F engine made by Frankensteining a 3FE. Essentially, a fuel injected 2F engine. I've never actually seen one so I can't say for certain if yours is or not. Someone should be able to tell us though. Do you see a carb anywhere? Do you have a choke knob next to the instrument light dimmer dial?
Where do you get the tensioner nut? I can’t find an alternative anywhereThe tensioner bolt and lock bolt are kind of hidden.
View attachment 1298447 View attachment 1298448
