Is there a reason not to reuse the Tee under the master cylinder?
I would reuse the fitting off the old lines that went to the tee, cut off the ABS fittings and double flare the fitting to the lines?
I have a metric double flare tool from Auto Zone. It goes has a spot for 4.75mm. Will it work? Are the lines 4.75mm?
I do not have the Toyota Tee and dont want to wait a week to order one.
Do I need some sort of Teflon tape or pipe dope on all of the fittings when hooking them up?
