Yeah, I was hoping that if I listed the obvious part numbers that someone would chime in with the rest. I looked on www.toyodiy.com but couldn't find the o-rings for either the expansion valve or the receiver & dryer assembly.
A very special "thank you" to everyone on this forum who is kind enough to take the time and help others with their expertise.
I would especially like to thank Ali (Alia176) for his July 2009 post on removing the evaporator and all it's little threaded metal friends.
I followed his step by step instructions and photos and the job was much easier than I expected with no unpleasant surprises.
Cutting the foam with a razor blade before opening the cooling box was brillant, and advising to remove the passanger seat for more room worked out perfectly. You sir are truely a GWKS!
What's more, the old, leaking evaporator was smaller than OEM
One of the biggest problems we see is poor fit of aftermarket evaporators. If they don't fit in the case correctly then you end up with either air bypassing the core or having to use a bunch of foam to seal it, which means less surface area for heat transfer. There's a reason they're lots cheaper than OE. Glad to hear you got it together with the right stuff. And thanks to Alia176 for this very helpful thread!
Wow - and I thought MINE was bad! I think oil leaks and coats the fins which in turn collects all the **** coming in the fresh air intake. I bet this one didn't smell so good (mine was definitely pretty stinky!) Another bonus of replacing this core is that your air will likely smell much better.
Just for future folks looking at doing this.
and the best oil for lubricating the evaporator and drier and O-rings: PAG DEC(double end capped) 46 oil
[FONT="]PLEASE correct this if you know better - before I finish sealing the system up and getting it evaced and charged.
[/FONT]
