I just did a head gasket job and had a valve to tight, well I fixed that and now there is an awful screech so I took the oil pan off, cylinders 2&4 need new bearings which is fine but it looks like the crank is hitting/rubbing where the main bearing is, is this because 2&4 are pushing it around or do I need a new crank? The engine is a 305 small block
