91 & 92 EFI Relay Spares
Discussion in '80-Series Tech' started by Hltoppr, Sep 9, 2003.
  1. Hltoppr
    Hltoppr SILVER Star
    2,023
    Media:
    4
    5
    Aug 29, 2002
    Port of Indecision...otherwise Northern Arizona
    I've heard that Autozone sells el cheapo replacements for the EFI relay on 91-92 FJ80s. Anyone have p/ns? I'm looking to get a couple replacements to throw in the spares box, not for quality...
    -H-
  2. cruiserdan
    cruiserdan SupportingVendor Emeritus Supporting Vendor Moderator
    20,564
    2,891
    Mar 27, 2003
    Surrounded by Cruisers from all over the world
    H-
    No need to apologize. No offence taken at all. That goes for all of you (yes, even Junk). When you need something, you need it. Simple as that.
    Sometimes the aftermarket guys can cross numbers using the OEM number. The OEM is a 90987-02004, replaced by a 90987-02004-83. Either one works. You may try giving them the OE number. FWIW the OEM lists for $11.21 and could be had for about 8 and a half bucks ;)
    D- :banana:
  3. Landpimp
    Landpimp GOLD Star
    14,687
    869
    Mar 14, 2003
    PNW
    there is also a Sorenson relay that is "supose" to be an upgrade, forget the parts number but it's out of a Caprice cop car I think.
  4. Hltoppr
    Hltoppr SILVER Star
    2,023
    Media:
    4
    5
    Aug 29, 2002
    ....cop tires, cop transmisison....cop relay?
    -H-
  5. Landpimp
    Landpimp GOLD Star
    14,687
    869
    Mar 14, 2003
    PNW
    [quote author=Hltoppr link=board=2;threadid=5120;start=msg39534#msg39534 date=1063144904]
    -H-
    [/quote]
    IT'S A 106 MILES TO CHICAGO. WE'VE
    GOT A FULL TANK OF GAS, HALF A
    PACK OF CIGARETTES, IT'S DARK,
    AND WE'RE WEARING SUNGLASSES.
    HIT IT.
  6. Rogue
    Rogue
    968
    1
    Mar 27, 2003
    Jefferson
    [quote author=Landpimp link=board=2;threadid=5120;start=msg39531#msg39531 date=1063144061]
    [/quote]
    Does a Caprice Cruiser have a different Fuse setup than a normal Caprice?
  7. cruiserdan
    20,564
    2,891
    Mar 27, 2003
    Rogue,
    Police package vehicles have different electrical syatems than run of the mill sedans. The relay mentioned by John probably relates to the light bar or siren. That stuff is all aftermarket and different departments set up thier cruisers in different manners. For example, the cars are usually delivered without light bars, prisioner barriers, shotgun locks, radio and KDT equipment, night vision interior lighting, ETC. The department garage mechanics set up the cars per department spec. Often no two cars are exactly alike, especialy if more than one mechanic sets them up. They evolve constantly.
    Dan.
  8. Rogue
    Rogue
    968
    1
    Mar 27, 2003
    Jefferson
    So it is just some higher capacity fuse? What is the deal?
  9. cruiserdan
    20,564
    2,891
    Mar 27, 2003
    Not a fuse, a relay. A relay that can handle more current without failing. The current demands for lighting and sirens on police cars are akin to winches for us.
  10. rustycruiser
    rustycruiser
    158
    21
    Feb 25, 2002
    Maryland
    My simple solution to the 91-92 EFI relay problem: I used to go through a few every year, especially during summer. About two years ago, I took a tube of silicon/dialectric grease and coated the hell out of all four prongs. Also jammed the grease into the relay holder. Never had a problem since then. I do go back and reapply the grease once a year or so, but have not had to replace the relay in the last few years. Hope this helps someone out there.
    Ross
  11. DanKunz
    DanKunz SILVER Star
    8,860
    Media:
    2
    523
    Feb 7, 2002
    Woodstock, GA
    FYI...tried aftermarket (el-cheapo)....
    Suggest you use only for a spare.
    My truck ran like crap on those...pop in a toyota...smoooooth.
    You can do it and compare..I saw a difference.
  12. kiddynomite
    kiddynomite
    23
    Dec 19, 2006
    Chesapeake, VA
    At the risk of sounding insane, where is this relay located?
  13. Fergie
    Fergie
    278
    1
    Oct 16, 2007
    Flagstaff, AZ
    In the underhood fusebox, driver's side.
  14. jonheld
    jonheld
    6,237
    915
    Dec 8, 2006
    New Jersey
    To be clear, the OEM relay is part number 909870200483 and the list price is $11.84.
    There is a drop in replacement from a Camry that is a green plastic can as opposed to stamped aluminum. Part number 2830016010. I can't seem to find pricing on that number, but it's not expensive. Perhaps on of our esteemed parts dudes can throw out a list price and double check that part number.
    The same EFI main relay is used on ALL 80 Series, 3F-E and 1FZ-FE alike.
    In any case an OEM part WILL work and doesn't cost much.
  15. jonheld
    jonheld
    6,237
    915
    Dec 8, 2006
    New Jersey
  16. caldentey
    caldentey
    165
    Mar 28, 2006
    Bend, OR
    what are symptoms of a bad relay? How can you tell when the relay is bad itself, does it burn out like a fuse? Thanks
  17. yohavos
    yohavos
    1,707
    Media:
    10
    632
    Aug 16, 2009
    Spokane, WA
    I'm a :banana:short of a :banana:, but through searching I found that I had a bad relay when my '97 would turn over but not start. Ended up browsing through 'mud and found when I turned my key to "on" I had no CEL whatsoever... popped in a new one from the local dealership (paid $16 :doh:) and she fired right up.
    [Someone help me out if I'm way off base here... :cheers:]
  18. Fergie
    Fergie
    278
    1
    Oct 16, 2007
    Flagstaff, AZ
    Well, I knew mine was bad when the GWB would start when cold, but not after running for a bit.
    Or, it would cut out on the 405 at 60mph, or on Alondra Blvd in rush hour traffic, or sitting in traffic in Venice.
    I started keeping a spare to switch out if that happened, but it never did once I replaced the relay.
  19. Patty Whack
    Patty Whack
    49
    17
    Jul 21, 2015
    Hawaii
    I just had this problem this morning - Solid cranking, no start. Before panicking i opted to consult this Forum, as y'all know way more than i do. In first search, threads comes up, identifying and symptoms and cause, and that this is a known issue (not to me until now) Check the relay, she's loose and pretty burnt, push it back into place, she fires right up, i go to napa get a replacement and a spare. Twenty years ago it would have probably taken me days to sort this out.
    Big thanks to all the cruiser geniuses on here that make it possible for a noobs like me to sort this stuff out without having an aneurysm. I've learned more about the LC reading this forum for a few weeks than i ever learned about Fords reading manuals, wrenching and rebuilding them for 10 years.
    Big Mahalos
    LS1FJ40 likes this.
