- Thread starter
- #41
Got the trans kick-down installed. Went ahead and replaced the trans pan gasket too. Not sure what we had done before, but it was leaking pretty bad.
Replaced the fuel hoses too and reconnected one of the diaphragm vents on the top of the tank. Still, the gas is still building up a lot of pressure in the tank and you have to open the gas cap verrry slowwwly unless you want to wear 91 octane. Still haven't figured out why the two vents on the top of the tank aren't working.
We also have a coolant problem. The dash gauge is not calibrated for the sbc350, but we can still detect when it's at running temp and when it is on the rise. Sometimes the coolant levels are high after running 15-20min and the overflow reservoir spills over. We are running the Waggy's stock radiator and overflow reservoir as well as heat exchanger. The thermostat appears to be working fine for this engine and it likes a running temp of 195-200 (measured with a laser pointer thermometer). [EDIT: we think we just had air in the system, and it's worked its way out now. All is normal on this topic.]
