85 4runner overdrive light flashing
Discussion in '95-older Toyota Truck Tech' started by jhnLennon, May 1, 2007.
  1. jhnLennon
    jhnLennon
    104
    Dec 27, 2006
    Whats up with my overdrive light flashing.Flashes for about 5 mins untill warm and then stops.I have confirmed that it is shifting into overdrive too.
  2. 2ndGenToyotaFan
    2ndGenToyotaFan Ice-Bound Moderator
    9,212
    45
    Jan 8, 2006
    It's complicated....
    That's telling you there is some type of problem.... On the later trannys there is a self diagnosis system, I think the early EFI/Auto trucks had it, but my FSM shows plugs that are probably different..... The steps are, turn thekey and O/D on (do not start truck) connect the "DG" connector to a chasis ground. (On my 89 the DG con. comes out of the wireharness on the drivers side of the engine bay.....)
    The O/D light will flash out the codes like the check engine light for other troubles....
    Maybe someone with an 85 FSM can chime in....
    I hope that helps some.
  3. WristPin
    WristPin
    2,690
    Media:
    9
    96
    Sep 14, 2005
    The NW, Cascade Mountian Range
    I checked alldata, and cannot find any info on checking for codes on a 85 transmission.
    is the transmission acting up at all?
    no where did i find any relevant info. i searched for about 30 mins.
    Sorry, I wish I knew more about these trannys :doh:
  4. jhnLennon
    jhnLennon
    104
    Dec 27, 2006
    I have an 85 fsm and it says I should have a a43d tranny which I dont(a340h),tranny seems to work fine but the light will come on for about five minutes and then shut off.There should be a diagnostic connector some where(has to be if the light is flashing,must be a code)my haynes manual says the wire should be yellow/white,there is a yellw/blue wire with connector near efi diag. connector
  5. jhnLennon
    jhnLennon
    104
    Dec 27, 2006
    OK,read the diagnostic codes and got code 61(#2 speed sensor)now can anybody tell me a good place to get the part?
  6. 2ndGenToyotaFan
    9,212
    45
    Jan 8, 2006
