82 fj40 front axle rebuild
Discussion in '40- & 55-Series Tech' started by Cruiserhead05, Jul 16, 2003.
  1. Cruiserhead05
    Cruiserhead05 SILVER Star
    3,464
    10
    Jun 25, 2003
    Marshall, VA
    How much does it cost to rebuild a front axle out of an 82 fj40
  2. woody
    woody Internet Fireman Staff Member
    10,329
    Media:
    303
    1,086
    Jan 15, 2002
    Toquerville UT
    how extensive?
    Parts for the knuckle rebuild is in the $100 range. Find yerself with busted innards in the diff and things can add up quick tho...
  3. Cruiserhead05
    3,464
    10
    Jun 25, 2003
    Marshall, VA
    Well my drivers side hub is leaking real bad. the passenger side is fine. they resealed the hub with new gaskets and still is leaking. they said the knuckle area of the axle may need work. on the inside of the wheel there is grease on the ball.?
  4. woody
    10,329
    Media:
    303
    1,086
    Jan 15, 2002
    Toquerville UT
    you need the knuckle rebuild kit and make sure it includes inner axle seals. Those inner seals separate the 90-wt in the diff from the moly lube in the knuckle. The knuckle felts/seals (where you see the grease) is a common leak point...mine are always greasy looking.
    IMO, if it don't drip on yer floor, it ain't a problem yet.
    See Morgan's writeup in the Tech Links for the process.
