80 vs. 100 series brake pads: Picture
Discussion in '80-Series Tech' started by lilevo, Dec 26, 2009.
  1. lilevo
    lilevo
    584
    16
    Sep 15, 2008
    53402, Racine, WI
    I haven't seen a picture of the comparison so here it is.
    80 series brake pads vs 100 series brake pads
    [​IMG]
  2. mudstorm
    mudstorm
    139
    1
    Jun 2, 2008
    peth
    yay i brought 100 series brake pads and slotted rotors my brakes ..are king
  3. PHIL O
    PHIL O
    306
    Media:
    3
    2
    Apr 4, 2009
    philippines
    ah, thanks for posting this comparison. which part of the 100's pad do they grind to fit in 80 caliper? or does it just slip in? it indeed has a bigger surface area for more friction (=stopping power):clap:
  4. mudstorm
    mudstorm
    139
    1
    Jun 2, 2008
    peth
    they slide strait in
    you do need slotted rotors tho
    the extra surfas aria makes excessive heat and tends to warp rotors
    installing sloteds fixed the problem and the pads seem to last longer when 4wding in mud
  5. lilevo
    lilevo
    584
    16
    Sep 15, 2008
    53402, Racine, WI
    It was a tight tight fit. The pistons had to be compressed to the max and I had to tap the pads in with a hammer, but they fit.
    Jvoight likes this.
  6. grizzlygibbs
    grizzlygibbs
    1,148
    Media:
    6
    245
    Sep 14, 2008
    Wenatchee, Wa
    I have not heard about slotted rotors. I though people were just installing oem rotors when switching to 100 series pads! That's what I did.
  7. grizzlygibbs
    grizzlygibbs
    1,148
    Media:
    6
    245
    Sep 14, 2008
    Wenatchee, Wa
    Sorry, I have heard of slotted rotors, but have not heard of warpage due to using 100 series pads and the need tof sltted rotors!
  8. cody c
    cody c
    4,641
    26
    Feb 20, 2006
    calgary
    Thanks for posting the pics, does anyone know if these are the same brake pad for your 96 as they are for a 92 (fzj80 vs. fj80)? Do you have the year or part # for the 100 series replacement pads you ordered? I may have to do this mod; with the extra weight/larger tires I have now my cruiser definately doesnt stop as well.
  9. SiRaDuDe
    SiRaDuDe
    819
    Media:
    8
    3
    Aug 10, 2009
    Puerto Rico
    As far as I know... They will not fit the '92 FJ80... only '93 FZJ80 and later 'till '97???
    The earlier FJ80 have 15" Wheels and the brakes are diferent... AFAIK...
  10. cody c
    cody c
    4,641
    26
    Feb 20, 2006
    calgary
    Thanks, Any idea on swapping to different calipers such as the fzj or 4 runner calipers?
  11. Fergie
    Fergie
    278
    1
    Oct 16, 2007
    Flagstaff, AZ
    They do not fit the 91-92 FJ80s...I learned this one the hard way. Neither will the rotors.
  12. UCBerzerkeley
    UCBerzerkeley
    677
    1
    Jan 31, 2009
    SF Bay Area
    also they DO NOT need slotted rotors. whoever said that, well, they were wrong.
  13. 1973Guppie
    1973Guppie
    8,740
    Media:
    31
    619
    Jan 31, 2003
    "the whale's vagina", CA
    just use regular rotors and 100 pads, with no squeal shims.......
  14. tblume
    tblume
    1,077
    2
    May 19, 2008
    willamette/umpqua divide
    fixed it for you..;)
  15. dnp
    dnp SILVER Star
    3,612
    984
    May 2, 2004
    Jackson, MS
    I'm about to do this upgrade and need some clarification: I am NOT supposed to use the "no squeal" shims with the 100 pads, right? Do you, instead, recommend using the spray-on anti-squeal stuff?
  16. SiRaDuDe
    SiRaDuDe
    819
    Media:
    8
    3
    Aug 10, 2009
    Puerto Rico
    Right... The reason for not using the shims is that the fit is so tight that they will not fit... you could reinstall them (shims) after the pads wear a bit.
    I found no need to spray on any material and the shims are not making any noise... the 100 pads felt to me to have a kinda rubberized coating anyways (I could be wrong maybe is was all the chemicals I was exposed to) :p
    Also I believe that the Spray on anti-squeal stuff is made just to be sprayed on your disks to clean them, this way removing any contaminant between your disk and pads that might be making them squeal/noise. This spray is not meant to go between your pads and pistons (as far as I know)... Having said that its always a good idea to spray on disk cleaner and make sure that your disks are very clean before installing your pads.. and try not to get grease (from fingers) on your pad surface:D
  17. Vanny
    Vanny
    1,009
    34
    Jan 12, 2006
    Ladner, BC, Canada
    This thread is perfect timing. I need to replace rear pads and calipers on my 94. If I read this correctly I just need to order 80 series calipers and 100 series pads...or should I order the 100 series calipers as well?
  18. deanf
    deanf
    78
    Dec 3, 2009
    N47º 12’ x W122º 10’
    And the 100 series is what years? '98 through . . . ?
    Yeah I searched around and couldn't find the specific answer.:flipoff2:
  19. Ebag333
    Ebag333
    8,161
    16
    Oct 3, 2006
    Medford, OR
    100 series calipers won't fit. Only the pads fit, and only in the front.
    '98-XXXX
    Call Cruiserdan and you will get the right parts. ;)
  20. deanf
    deanf
    78
    Dec 3, 2009
    So is the correct answer '98-'07, given that we have a forum that covers "200-series 2008 Land Cruiser/Lexus LX-570" ??
    :confused:
