arcteryx
Supporting Vendor
Note- I will update the 3FE starters soon.
My starter on my 94 was going out. I wanted to replace it with the larger 2.2 KW starter. I figured I would write this up so others can see the difference. I am sure this is elsewhere but maybe not.
Below are 4 starters for 1FZ and 3FE engines. The 1FZ has 3 starters, the 3FE has 2.
1- 12V 1.4KW, part # 28100-66040
2- 12V 2.0KW, part # 28100-66060
3- 12V 2.2KW, part # 28100-66050
4- 3FE TBD soon as soon as I find the 2 starters in my stockpile
Below are pics of the 3 1FZ starters and a 80 series 3FE. My 94 came with the small 1.4KW, southern truck so the higher KW ones were not always offered from what I understand.
The size between the 1.4KW and either of the 2x KW is very noticeable. Between the 2.0KW and 2.2KW, the yoke is slightly bigger. You will also notice the 3FE is reversed as it resides on the right side/US. passenger side. US spec 1FZ started on the the left/driver side.
If you live in the south or someplace where it is warm, the 1.4KW will suffice. If you are want to the the overachiever or live someplace where it gets cold, you should look at one of the the 2.x starters.
Pics below are from Left to right
3FE, 1.4KW, 2.2KW, 2.0KW. It may not look like it in this pic, but the 2.2 has a bigger yoke than the 2.0.
2.0KW, 2.2KW, 1.4KW, 3FE
