76 fj40 disc brakes to 72 front axle
Discussion in '40- & 55-Series Tech' started by megolfer, Jan 29, 2003.
  1. megolfer
    megolfer
    1,964
    92
    Jan 29, 2003
    I was wondering if anyone knew how hard and what was needed to convert my 72 front axle to 76 frontdisc brakes
    thanks
  2. wayne_fj40
    wayne_fj40
    252
    Dec 31, 2002
    It depends on If you are putting up the front diff no big deal will probaly just have to redo the brake lines If you are just swapping the brake stuff there is a little more work invoved but easy pop out you're birfields and reintall the others with new brake setup and then run new brake lines In my head Its easy typing It out Is differentbut the answer is It is easy to do just takes little time...
  3. megolfer
    megolfer
    1,964
    92
    Jan 29, 2003
    I just want to swap the brake parts. If anyone knows of any websites that have instructions on this I would appreciate it.\
    thanks
  4. woody
    woody Internet Fireman Staff Member
    10,329
    Media:
    303
    1,084
    Jan 15, 2002
    Toquerville UT
    read thru the tech links on here...all the disc conversions discuss it, in detail, and should cover most/all yer questions.
    Really, it's about a 3 hour project, if you are experienced in front axle disassembly...6 hours if you are not...lol
    (I've done it so many times, I like to shoot for 2-1/2 hours blindfolded....lol)
  5. megolfer
    megolfer
    1,964
    92
    Jan 29, 2003
    Basically i would like to know the parts that i will need. Im buting some disc brakes and need to make sure i have all the parts.
  6. woody
    10,329
    Media:
    303
    1,084
    Jan 15, 2002
    Toquerville UT
    you need everything not connected to the empty housing....lockouts, spindles, bearings, rotors, knuckles, birfields....inner axles are optional, but may as well get those too.
    Easiest way? Drop the tie rod. Remove the knuckle wiper seal and felt, 8 bolts per side IIRC. Remove the steering arms and bottom trunion caps from the doner knuckle, 8 nuts.
    Pull....hard...the knuckle complete with the inner axle attached will come out, and that's what you need to swap onto your current drum axle. ;)
    it's gonna be greasy....so drag along some extra rags....
  7. megolfer
    megolfer
    1,964
    92
    Jan 29, 2003
  8. woody
    10,329
    Media:
    303
    1,084
    Jan 15, 2002
    Toquerville UT
    thinking a bit more, you will likely have to remove the outermost portion of the lockouts too on the doner...and then the outer clip or fenderwasher/bolt on the birfield. The birf needs to be rotated a certain way to come free from the knuckle, and with the spindle on, etc, that will be impossible to see or adjust.
    I think that's it tho....I'd still do it blindfolded...lol
  9. ledge
    ledge
    38
    Nov 17, 2002
    I am looking to do this same thing to my 73. Is there a preference for which year the disks come out of? I am also planning my time schedule. If woody does it in 2.5 hours and somebody with no clue can do it in six. I figure it will take me a full day and a case of longnecks. ::) :D
  10. Niner
    Niner
    821
    Jun 4, 2002
    Readfield, WI
    I'd just give a blindfold to Woody, and split the case of longnecks with him. :flipoff2:
  11. woody
    10,329
    Media:
    303
    1,084
    Jan 15, 2002
    Toquerville UT
    Well, disc fronts are 76+...but 79+ knuckles have the better/larger steering arm pattern and also should have the slightly bigger/better minitruck-sized birfields. Given the choice, 79+....but ya can't be too choosy some days. You can also use the 79-85 minitruck knuckles, but you then need to deal with the solid rotors. (all discussed in the tech links)
    longnecks....mmmm....:beer:
  12. ledge
    ledge
    38
    Nov 17, 2002
    Its kinda a long drive, and someday I might be the one that has to do it blindfolded. I cant move the LC anyways. I dont have a trailer, and the current condition could best be described as pieces :)
