Thanks Mace! Speaking of "Bad Ass", I just installed a Trail Tailor bumper up front. The thing fits like a glove and is VERY well constructed. I'll post some detailed pics once I get the sliders mounted up.
For all those looking for looking for custom fab work, I could not be more pleased with the craftsmanship and customer service from the TRAIL TAILOR. View attachment 1035972
As soon as I decide to give my brother this old Warn Bellevue winch I have sitting here I'll order up one of Jason's front winch bumpers (without the plate).
I agree, his stuff is very well made and great pricing!
New rear main seal and pilot bearing installed. The Koyo pilot bearing is no longer available from Toyota.
Napa sells an Altrom (repackaged koyo) for $7 . View attachment 1041954
Yep- the Aisin CKT-032 Clutch Kit includes it. I had a good disc and pressure plate on the shelf, so I'm having to piecemeal it together.Pretty sure that is the same one that was in my Aisin clutch kit.
J
I believe Georg (orangFJ45) is possibly going to be making shortened FJ60 rear axles to make it easier to install split transfer cases. Currently leaning on doing split case in my 79 instead of my 73 FST. If I did you go with the 73 I thought about grafting the piece with the hand brake mount from a 79+ floor to a earlier transmission cover. Won't be that much extra work to remove the handle to take the cover off. 72 was mix of dash transfer case shifter or floor shifter. Believe it was because the dash shifter linkage that the clutch fork was on the left side. Believe it was a couple of years before it switched to right side. I remember the speedometer cable and hand brake cable has to be routed so it's didn't interfere with the clutch fork. I've never switched a early driver's clutch fork to the passenger's side so not sure if there is clearance issues but would think it would be a better option.
That would be way cool for my mythical H55F/split case install in my FJ-55. Is Georg doing these?
Although the 3 speed and transfer shift great, I am a little concerned about driving 800 miles, wheeling for a week and then turning around driving another 800. I've cracked an early case before and don't want to go through that again.
I have a later style 4 speed with a split case but that leaves me with no parking brake, which is a must when driving up a mountain.
Many years ago I had a 81 fj40 rear end with the parking brakes on the rear drums. At some point I remember selling it to a guy in Ga for $100. (Doh!). Had I kept it, it would allowed me to run the split case.
After a few searches the only 81-84 fj40 rear axle I could find was priced north of $1200. That's more than I can plunk down.
After a few more internet searches, I found a NHRA chassis shop that can narrow a 60 housing 2" + add 40 spring perches.
This will allow me to use a stronger transfer and retain the parking brake using all Toyota parts.View attachment 1021073View attachment 1021074View attachment 1021075
Thanks guys.. I really appreciate it. It doesn't matter to me if its simple or complex. Custom is whatever you want.. I seriously need a therapist. Like I said.. the freakier the better. Here is my new 60 bumper creation.
Jason
Dude... That is crazy!
sorry for the sideways post:
meant for reevesci: have you ever made anything for an LX450 ?
A few comments, Pablo, I'd say the rear wheel E-brakes are far better. For one, if you loose a driveshaft or axle, they will still hold the vehicle, not the case with the transfer case brake. They also have more surface area, so better holding power. I find the e-brakes on my 60 and T-100 to hold very well, plus they are the adjusting mechanism for the rear brakes, so no more manual adjustments on the rear. My FZJ80 is another story, I have messed with it three times now, decided maybe the cables were stretched and got a new Toyota cable set for it and still no better.
I still wonder, looking at the pictures here and working on both, it seems the flange on the rear axle shaft is obviously different and located slightly more outboard on the late axles. I wonder if an adapter could be built that matches the 6 hole pattern on the early 40 axles on the back side, with the wide 4 hole pattern on the front, similar to the adapters used to put calibers on the rear. Seems that would be the easiest way to convert lots of early axles to the later brakes and allow split cases to be run.
As for using the hand brake. My T100 uses a hand brake under the dash, just like all the pickups of that time. The rear brakes are virtually identical to the 60 series. The 60 uses the mechanical advantage of the brake lever and large half round surface to pull the cable. On my pickup, the lever under the dash works just like a 40, with less mechanical advantage actually. But mid frame there is an arm that it pulls on. This arm is quite simple, but it gives an additional mechanical advantage to engage the rear brakes. It take far less effort to set the brake than my 40 or 60, and holds tighter. This same setup could easily be built on a 40, perhaps under the drivers seat, outboard of the frame, all it would take is a simple bracket. Perhaps the 60 cable could be run to the arm, and the 40 hand brake cable to the other part of the arm.
http://www.villagetoyotaparts.com/images/parts/toyota/fullsize/460087A.jpg
Arm is 46301, front cable pulls outside, (left side) of arm. It pivots on the pin in the picture and rear cable to backing plates attaches at in the middle hollow spot with 46441 nuts for adjustment. The picture does not show it, but there is a long spring to help with return, nothing special. Although looking at it and thinking about it, the front cable has to have a great deal of linear movement to pull the arm, perhaps more than a 40 cable provides, it would be proportionate to the arm length.
