700R4...pain in MY A$$!!!
Discussion in '40- & 55-Series Tech' started by TJDIV, Aug 14, 2003.
  1. TJDIV
    TJDIV Back in The U.P.
    2,063
    Media:
    9
    2
    Jan 28, 2003
    Upper Michigan
    Dammit man....so I left my cruiser for a couple weeks while on vacation to get my 700R4 done. Well...vacations gone and the cruiser's still on the rack? Drive shaft in the rear needs to be 9" center to center and nobody can do it? Bull. Not too mention the fact that it just doesn't look like the AA kit is all it was cracked up to be. Why in the hell is it almost 8" deep??? Any suggestions would be great at this point before I start throwing (more) things.
    1970 FJ40 Chevy 350 AA kit for 3 speed to 700R4. Everything is installed so far, just can't seem to get the drive shafts made.
  2. hammerhead
    hammerhead
    1,995
    Jul 5, 2003
    Central, Utah
    Sounds to me like you need to flip your rear springs around moving the axle back a few inches. Is your motor pushed as far forward as safely possible?
  3. Rice
    Rice SILVER Star
    3,275
    Media:
    10
    2,577
    May 2, 2003
    GSO NC
    Now that's a short shaft. Check out the "Tom Woods" custom shaft web site and see what they can do.
  4. Rice
    Rice SILVER Star
    3,275
    Media:
    10
    2,577
    May 2, 2003
    GSO NC
    For curiosity, how far up did you move the engine??
  5. TJDIV
    2,063
    Media:
    9
    2
    Jan 28, 2003
    Upper Michigan
    See, that's just it, had to build the drive shaft and now the angle is to much for the length and it drives like dirt. The spring idea sounds decent, and I know for a fact we could move the motor another 4 inches forward. Hmm....
  6. TJDIV
    2,063
    Media:
    9
    2
    Jan 28, 2003
    Upper Michigan
    Oh...and my transfer case just decided it didn't want to cooperate anymore. Droppin teeth like Tyson on that bad boy....shoulda kept my Tahoe.
  7. hammerhead
    hammerhead
    1,995
    Jul 5, 2003
    Central, Utah
    Wash your mouth out with soap! :p
    What caused it to frag? The only t-case gear damage I've seen was caused by shifter damage only partially engaging teeth. Once pieces of the engagement teeth started flying around in there it wasn't long before it was destroying every gear in the case. UGLY!!!
  8. CruisinGA
    CruisinGA
    6,163
    8
    Mar 27, 2003
    Georgia Tech
    [quote author=TJDIV link=board=1;threadid=4339;start=msg32601#msg32601 date=1061056169]
    [/quote]
    If you wanted a chevy, yeah keep the tahoe, if you want the best 4x4 rig ever, buy a toyota, and keep it toyota. :flipoff2: :p
  9. TJDIV
    2,063
    Media:
    9
    2
    Jan 28, 2003
    Upper Michigan
    Frustration is my fuel. This too shall pass. . . . . To quote a guy from Alabama....."I'm buildin' me a munster"....end of story.
  10. CruisinGA
    CruisinGA
    6,163
    8
    Mar 27, 2003
    Georgia Tech
    Seriously, flip your rear springs and move the engine as far forward as is safely possible, and see where you are then. I would think you would now have at least a ~16" driveshaft. Still kinda short but not 9". :eek:
  11. lndcrzr71
    lndcrzr71
    34
    Apr 20, 2003
    i have an r4 in my 40 in back of a 350 and i had to move my motor up as far as i could and then move the radiator an inch or two more to fit a seven blade fan for cooling.i had to put a c/v joint in my d/s to make up for the angle.
  12. TJDIV
    2,063
    Media:
    9
    2
    Jan 28, 2003
    Upper Michigan
    I'll look into doing that tomorrow. Flip springs, move the engine. WoW!! This is going to be a blast....ugh. Thanks for the tips.
  13. TJDIV
    2,063
    Media:
    9
    2
    Jan 28, 2003
    Upper Michigan
    what do you think about shims on the d/s to compensate for the angle, since we've already got the thing "technically" together and driving, however the d/s angle is a little much causing 'trouble'. Just wondering if shimming it would work to compensate, or I guess the c/v joint idea wouldn't hurt along with shims. A lot to fit into 9 inches. (who'd have thought 9 inches was too small....)??
  14. lndcrzr71
    lndcrzr71
    34
    Apr 20, 2003
    ive never heard of shimming any d/s i think that will only make it a shorter distance
  15. TJDIV
    2,063
    Media:
    9
    2
    Jan 28, 2003
    Upper Michigan
    it would have shortened it...shims were on the rear axle mounts, not the d/s, sorry, it actually worked really well, leveled out the angle...now I just have to figure out if the gears for a 73 t/c will go into my 70.
  16. lndcrzr71
    lndcrzr71
    34
    Apr 20, 2003
    yea ok i was wondering about that.i have 6 degree wedges in my rear axle,that worked out ok now i added longer rear shackles to also help even things out.
  17. theo
    theo
    1,432
    Feb 19, 2002
    [quote author=Rice link=board=1;threadid=4339;start=msg32373#msg32373 date=1060949146]
    [/quote]
    Rice has it. Try the "Geometry 101" page. It might help you decide what you can get away with.
    http://www.4xshaft.com/
  18. hendo
    hendo
    181
    Sep 10, 2003
    san fernando valley
    i went througth the same ordeal take indcrzr advise move the radiater foward atleast 1.5" move the engine forward atleast 4.5" its a little work but other wise you will have alot of problems with a little drive shaft as you will definately need to run a cv oh another thing you better tilt your engine up to lessen the angle of your rear shaft also other wise you be going througth drive shafts every other trip,i have a nv4500 a little long than a 700r4 and now i have a 20"c to c on my shaft even with the rear end moved back
