i was fighting a high idle problem and replaced the coolant temp sensor. The idle came down and get close to 2mpg better milage. But i didn't start out at 6mpg.
Hello, having a issue with my rig, it is using ALOT of fuel. I was expecting 11-13mpg with 33's. But I got 6mpg. Constantly.
Specs are
33x12.5r15 tires
4" lift
arb bull bar
No engine light or rough running.
I have done
new spark plugs
new plug wires
new cap and rotor
new air filter
egr and smog delete
valve adjustment
Seized caliper(replaced)
new oil in everything
re built a440f trans with new torque converter.
What do I do next!? It has a little power but nothing above or below average. I am running 87 octane in the tank. I have run 3 cans of injector cleaner though it over the past 5 months. Could the cat converters be pooched? I have a lot of suit on the tail pipe too. Could leaning out the afm help? I don't know much about the 3fe so what advice you have is helpful
A lot of people have made threads on bad mileage but they are getting 8-9mpg, mine is at 6 and the engine seems to run great with no stumble or hickup.
HELP ME! I am spending a fortune on gas! A tank only lasts 200km/120mi!!!!!!!!!!!!! I am not hard on it either I cruze at 100km/h -60mph no hard starts or hard acceleration.
Hi all,
Stock FJ80 tires are roughly 30 inch diameter. Your vehicle's transmission ratios, axle gears, and ECM programing was set-up for those 30 inch tires. You have also added extra weight (bull bar, etc.) and wind resistance (lift kit, taller tires) to the vehicle.
IMO, re-gearing your axle gears to 4.56 would help put the rig back into the power band of the 3F-E engine.
Regards,
Alan
I run 31x10.50 BFG AT KOs and the only mod I have is a TJM aluminum bumper that weighs less than the stock bumper. And I've removed the third row seats. My truck is actually weighing less than when I bought it 23 years ago new. It isn't the tires or weight. It's the 234k miles and maintenance/tune up needed.
Any updates on the 3FE performance? I'm getting 8-9 MpG and trying to figure out why. I used to get 10-12 pretty regularly with same setup. All maintenance is up to date. Curious about temp sensor. I haven't replaced that.
I was addressing aggiesdm's question since usually a plugged cat causes a significant loss in MPG. Sorry for the confusion. As far as your situation LS1fj40, a couple things come to mind, I would check the FPR. If fuel pressure is too high it could cause a rich scenario. AFM could also cause it. Also check vacuum lines for leaks and tears which can throw things off, might be good to replace all your vacuum hoses-cheap and easy. And the distributor could also be an issue as mentioned in my last post in this scenario as well I think. Hope this gives u some ideas. I have no idea how you would test the distributor for proper advance to confirm your old one is working properly. Some of the older knock sensors had issues as well if your motor has one. Im more experienced with the 3vz-e and 3vz-fe but they have similar efi as the 3fe I think.Cat is free flowing. Had it pressure tested when I replaced the O2 sensors. It is "perfect" according to my muffler shop. I suspect that is because the 2nd O2 sensor was just hanging and I've been burning rich so she's nice and clean. I was prepared to cut it out and eliminate it but he tested it three times and it's clean as a whistle.
