62 drive train in a 40
Discussion in '40- & 55-Series Tech' started by Gumby, May 24, 2003.
  1. Gumby
    Gumby Supamod Staff Member s-Moderator
    11,778
    307
    Dec 13, 2002
    Knee deep in hookers and gin
    I'm just about fed up with my 350. Will a 62 drivetrain - 3fe/auto/xfer/axles fit in a 40 or is it too long? I realize I will gain width. It'd be worth it for the fine spline, gussetted axles with front discs. I'm also having turning radius issues with 35s.
  2. woody
    woody Internet Fireman Staff Member
    10,332
    Media:
    303
    1,089
    Jan 15, 2002
    Toquerville UT
    outta fit with reversed rear springs...don't forget you need to outset the front springs too since the 60 axles are ~3" wider and the passenger spring aligns ON the pumpkin.
  3. Chef
    Chef
    1,972
    6
    Jan 24, 2003
    Columbia, MO
    I think it'd work ok, with a huge loss in power:) There's several guys on the por running 60 axles, go there for how to. Definatley gonna have to reverse rear springs to driveline length...there's gonna be a lot of wiring to do to get compter up and running on the 3fe...What's your 350 doing wrong? It's gonna be waaaay easier to fix that...
  4. Gumby
    11,778
    307
    Dec 13, 2002
    I'm thinking I might just put in the axles and transfer case. I won't have problems with the leaf springs on the front 'cause there ain't any on my junk. :D
    The questions now center around what years trans I have to use.
