- Thread starter
- #41
The three with the green connectors that sit on the fenderwell. It run fine as is, and is desmogged, so I don't know if they are needed
I just thought of an easy test you can try to see if that clipped wire might be for the thermal sensor for the carb cooling fan. After you run the engine up to temperature and have shut off the engine and removed the key from the ignition, if you don't hear the carb cooling fan kick on, try temporarily touching that clipped wire to ground (chassis) and listen to see if the carb cooling fan kicks on. If it does, then that's the wire. If it doesn't, it still might belong to the thermal sensor on the carb cooling fan, though, it just means that there is another component on that circuit that is also bad (like the 'Dome' fuse or the carb cooling fan relay or timer...).There is a single wire that is clipped. Makes sense that it may be for a sensor. I'll look for those two locations you mentioned. It does appear that the wire may be for a sensor.
Taller shackles
If the inspection becomes an issue registering it in SC might be an option. I do not know the exact wording, but, if you store your vehicle in SC more than half the year you can register it in SC. Heather knows the details. I could write you a storage contract for the shop address and you register and insure it in SC. Drive it where you chose.
