60,000 belt replacement?
Discussion in '80-Series Tech' started by billdavis518, Aug 21, 2003.
  1. billdavis518
    billdavis518
    18
    Aug 15, 2003
    Should this be done at 120,000 miles as well? How difficult or expensive to have it done?
    Thanks ...
    Bill :D
  2. firetruck41
    firetruck41
    5,732
    10
    Mar 27, 2003
    Camas, WA USA
    [quote author=billdavis518 link=board=2;threadid=4498;start=msg33691#msg33691 date=1061464341]
    Should this be done at 120,000 miles as well? How difficult or expensive to have it done? [/quote]
    If you are reffering to a timing belt, the 80 series don't have them, they have a timing chain which should last the life of the engine, and don't need changing usually. If you are referring to the fan/alternator belts, it's a good idea to change them if you have a service manual or minimal mechanical abilities you should manage to figure it out in an hour or so, use the OEM belts as they are quieter and were only $25 for the set on my 93 FZJ80. I would guess a shop might charge an hour labor to do it.
    If you have a 100 series then you do have a timing belt which should be changed every ~60k - ~90k IIRC.
