Drivetrain swap: FJ55 (6/72) gets FJ60 stock drivetrain
This thread documents a plain vanilla powertrain swap.
The target vehicle is a 6/'72 US FJ55 which is completely stock except for a Webber carb. The F motor is dead. The transmission is 3 speed, as is the transfer case.
A '84 FJ60 (unknown month) has donated a running 2F (with headers and a Weber 32/36), a 4 speed transmission, and a split transfer case (34mm idle shaft). Additionally a 10/83 FJ60 is available for most all parts.
The plan is to put the '84 FJ60 engine+tranny+T/C in. After that is up and running, next is to swap the rear axle to the second FJ60's for the parking brake, as well as the stronger parts and 3" wider stance. The third part will be to put the FJ60 front axle knuckles on for disk brakes. Adding power steering will probably not happen at this time.
