I am currently in the process of swapping a 6.2L L92(Escalade version of the LS3) with the corresponding 6L80E automatic transmission into my '94 80. The engine came from a 2008 Cadillac Escalade and features VVT(Variable Valve Timing). This allows for both low end torque and high end horsepower. The stock engine is rated at roughly 400HP/400FT-LBS at the crank. I am debating doing a cam swap to open the motor up a bit more, so we may see as much as 450HP/TQ when it's all said and done. The transmission will have both automatic and tapshift modes when I'm finished.
My goal for this swap is two fold. First is to create a capable sleeper that will function well as a DD. Second is to utilize this process as a prototyping process and develop a full plug 'n play swap kit. My intention is to provide everything necessary to install an LS engine into an 80-series for the DIY guy or a mechanic to install. This would include motor mounts, transfer case adapter, wiring harness, exhaust, power steering lines, ac lines, radiator hoses, etc. This is a large undertaking and I don't have a firm date/deadline at this point, but I am actively working on this with the goal to complete it as soon as possible. I am working with a few vendors to have the various components produced once I have finalized the design/prototype phase.
At this point in the swap, I have the old motor out and the new motor/transmission sitting in the engine bay. I did a LOT of research with regards to oil pans and found that the pan from an H3 Alpha is the same depth as a regular truck pan, but is about 1.5-2" shorter front to back than a regular truck pan. This gives almost enough room for the tie-rod to clear. I still lack about 3/4" for the tie-rod to clear the oil pan, but I have a plan for that. Other than the tie-rod issue, the front axle clears everything at full bump quite nicely. There is a small casting tab on the bellhousing of the 6L80 that has to be ground down for the driveshaft to clear, but once that is removed it fits without issue. The pan on a 6L80 is centered and allows sufficient clearance for the driveshaft at stock height.
I am currently working on the exhaust options as that is the biggest hurdle with keeping the truck low. Right now it looks like the exhaust can be snaked around the front driveshaft and transmission to merge into one pipe somewhere in the vicinity of the t-case and then carried back to a single exit point in or around the stock location. The other option is to go outside the frame rails on either side for true duals, but I don't think that will be desirable to many people, myself included. I am waiting on a couple of different manifolds to arrive to see what can be done with off the shelf parts. I would prefer not to have to build custom headers strictly for this application, but I'm not ruling it out.
Once the exhaust is complete, I will finalize the motor mounts and proceed with wiring and plumbing. I'm hoping to have the swap wrapped up and in testing by the end of January. I get about 4 hours/night on the project 4 nights/week, so hopefully that should be sufficient time to get it done.
Here are some pics:
Engine nestled in the engine bay.
Driveshaft clearance at the transmission pan at full bump.
Current location of tie-rod with H3 pan installed. This is roughly 2-3" from full bump. As you can see there is interference. I think I have a clever way to resolve that without major surgery, but I won't know until next week sometime. The good news is that the tierod moves forward significantly when the tires are turned, so this is the worst case condition. With the wheels turned about 10* I can set the truck on the bumpstops with ample clearance.
Here are some pics:
