40 Series Fluid Capacities
Discussion in '40- & 55-Series Tech' started by Hugh Heifer, Sep 2, 2007.
  1. Hugh Heifer
    Hugh Heifer Stapler....where's my stapler. ... SILVER Star
    5,993
    Media:
    26
    353
    May 10, 2006
    Makati!
    I have done a bunch of searching and discovered some of the other series had a thread dedicated to their fluid capacities as well as types of reccomended fluids for their vehicles. I may be mistaken but did not see that for the 40. So here is what I comiled from one of the "more useful" commercially available manuals:
    Engine Oil: 8.5 qts Weight specific to environment
    Axle Lube: 2.6 qts SAE 90 Weight
    Steering Gear: 0.6 qts SAE 90 Weight
    Power Steering: Dexron II (or newer) Automatic Transmission Fluid
    Coolant: F Engine 17.5 qts
    2F Engine 19 qts
    1978 19.9 qts
    1979 - 1982 16.9 qts
    Fuel: 18.5 Gallons (pre 09/73)
    16.4 Gallons (09/73-12/78)
    22.0 Gallons 01/79 and later
    Clutch: Dot 3 or SAE J1703
    Brakes: Dot 3 or SAE J1703
    Transmission: All SAE 90 Weight
    Three Speed: 3.6 Pints
    Four Speed: 6.6 Pints
    Transfer Case: 3.6 Pints
    Transfer Casew/ PTO: 4.4 Pints
    PTO Winch: 1.2 Pints
    As with some of my other posts, these are publsihed and not my own idea so don't punish the messenger if you feel they are wrong. I also did not recommend a weight on the engine oil (for obvious reasons) or a type of coolant (I just know Dexcool should be avoided). Any input on coolant or oils for a specific climate or set up could be
    useful here.
    I also beg that any of the other threads on capacities and oil/fluid debates get linked to this for FAQ. I think we would all find those useful in one place.
    Here is a Tranny fluid discussion ...>LINK<
    And an Engine Oil discussion ...>LINK<
    Synthetic brake fluid discussion ...>LINK<
    Red V. Green Coolant Discussion...>LINK<
    :cheers:
  2. Poser
    Poser Oh...Durka Durka Durka. s-Moderator Supporting Vendor
    19,928
    Media:
    17
    183
    Oct 1, 2003
    MN
  3. 3_puppies
    3_puppies SILVER Star
    7,957
    146
    Dec 2, 2002
    Helena MT
    I'm thinking the gas tank in 79+ 40's is 22 gallons???
  4. Sea Knight
    Sea Knight SILVER Star
    2,502
    196
    Apr 19, 2006
    Austin, Tejas and Laurel, Mississippi
    I believe you're correct. In some manuals the 79+ FJ-40 fuel capacity is listed as 21.7 gallons and in others it says 22 gallons. I've pumped 21.5 gallons into my '82 after driving on empty for longer than I should. :rolleyes:
  5. Volcano cruiser
    Volcano cruiser
    1,317
    3
    Aug 18, 2008
    El Salvador and Washington, D.C.
    My 1980 BJ40's tank holds 23 gallons, if you include filling it up to the top of the fueling spout with diesel.:D
  6. Hugh Heifer
    5,993
    Media:
    26
    353
    May 10, 2006
    Makati!
    Weird. I copied all these out of the manual :meh:
  7. Sea Knight
    2,502
    196
    Apr 19, 2006
    I can't find my "official" FJ40 Owners Manual, but FWIW Cool Cruisers sells replacement OEM Toyota fuel tanks and their catalog lists the fuel capacity of 1/'79-->'83 FJ40 tanks as 22.4 gallons.
    Gas Tanks
  8. Holdengemini
    Holdengemini
    2
    Nov 26, 2010
    40 series rear diff axle capacity
    Hello All!
    Just curious as the the rear axle fluid capacity of my 1974 FJ45.
    I know my manual says 2.6qts - As im an aussie 2.5Lts.....
    I have had some resistance from a friends dad telling me this is wrong....
    He is under the impression that the fluid level in all diff are measured to the bottom of the filler plug in the housing.
    If this is "correct" the rear diff axle capacity would be 3.6qts - 3.5lts....
    I'm confused what to believe as he is adiment that you always fill a diff to just below the filler plug........
    Could you guys please set me straight!!!!!
    Cheers Jeremy.....
  9. FeralBrown
    FeralBrown
    3
    Feb 1, 2011
    Hanging Rock, NSW, AU
    I'd also like an answer to Jeremy's question, if anyone has it...
    Might be an Aussie thing to just fill to plug level, but I've heard that a lot lately, too...
  10. 1973barnfind
    1973barnfind
    395
    2
    Feb 24, 2011
    Hudson Valley, New York
    okay, so what harm could be done if you fill up to the fill plug 'till 90 wt pours back out?
    clarke likes this.
  11. skidplate
    skidplate
    1,591
    Media:
    12
    523
    Oct 26, 2008
    I think that's how most of us do it. just leave the plug out for a few minutes and let it kinda level out.
  12. Mechnizer
    Mechnizer
    58
    Media:
    11
    13
    Sep 3, 2012
    Phoenix, AZ
    I'm a 30 year Mechanic, All the shops I have worked for and all the mechanics I have worked with have always filled diffs, Manual trans and t/c's until the the oil drains out the fill, letting it stop drooling and then capping it.
    Conclusion would be that the Manufacture is required to state something to capacity.
    I have never had any damage done to my rigs doing it to the drain out method.
    Although if you where to over fill any unit beyond this drain method the oil will be subject to churning by the components inside and the oil would eventually be full of air homogenized !
    Seals and bearings would also be subject to failure .
    Island Hopper likes this.
  13. JohnnyC
    JohnnyC Long ago TLCA# 2231 SILVER Star
    13,677
    Media:
    130
    1,712
    Jun 17, 2005
    Albany, NY area
    AFAIK engine oil capacity is 6.5 qts for the F135
