Chris, Re: "With the bypass hose installed, can the TC fluid level be effectively maintained via the tranny?"
In my particular experience, the bypass hose keeps both the tranny and the tcase level...
I can't recall which is higher (tcase, I think) and my 40 is undergoing an engine rebuild, so is not available to look...
Assuming tcase is higher... my tcase has a slight leak into the tranny... overfilling the tranny... the tranny overfill flows through the bypass. back to the tcase... voila! the tranny and tcase remain level.
But, being paranoid, I always check both the tcase and the tranny fluid levels.
EDIT:
If your intent is to never remove the tcase plug... I can't say that every ones' (your's included) experience will be the same as mine.
My cheapo HF 12V Impact Driver comment was meant to impress you with the fact that it doesn't have enough power to snap much of anything. SO, I can keep at it and never worry about breaking something.
Are you sure your tcase plug wasn't put on with red loctite (which releases at about 500 degrees)? Maybe you can hit the plug with a propane torch for a few seconds and then drive it out... that's what a gunsmith had to do with the sights on my new M&P Shield. Smith and Wesson install the factory sights with red loctite.
EDIT:
