4.56 ring pinion
Discussion in '80-Series Tech' started by landtoy80, Jun 21, 2003.
  1. landtoy80
    landtoy80
    5,668
    241
    Mar 13, 2003
    North Front Range, CO
    Does Toyota have 4.56 gears, if so can dealer get them?
    Are there vendors to stay away from that sell junk4.56 gears?
    kurt
  2. cruiserdan
    cruiserdan SupportingVendor Emeritus Supporting Vendor Moderator
    20,605
    2,983
    Mar 27, 2003
    Surrounded by Cruisers from all over the world
    Kurt
    Christo can get you OEM 4.56 gear sets from an off-shore source. Toyota proper does not export that ratio to this market(north america)
    Dan
  3. landtoy80
    landtoy80
    5,668
    241
    Mar 13, 2003
    Thanks, I looked on Slees web site and he doesn't show them their. I will e-mail them.
    kurt
  4. landtoy80
    landtoy80
    5,668
    241
    Mar 13, 2003
    I see TPI has them for about $190 for front diff. Don't know about if they are good or not ??? If I could get a set for under $400 I would but any more I will have to wait.
    kurt
  5. cruiserdan
    20,605
    2,983
    Mar 27, 2003
    The OEM gear sets will very easily exceed that. I would not be surprised if they are around $700.00 a set (That's per AXLE, not per vehicle :ugh: )
  6. landtank
    landtank SILVER Star
    18,425
    601
    Mar 27, 2003
    Groveland MA
    I have Yukons but in the 4.88 variety. The web site didn't show 4.56 in a reverse cut though. That was at Randy's ring and pinion. You might call them. Someone had posted that they were told something about lockers making a difference, was that you? Any way front and rear with bearings and seals was around 800.00 for the whole job. Almost 20k with no problems. Changed the gear lube last week and it was clean and nothing abnormal on the plug magnet.
  7. Photoman
    Photoman SILVER Star
    1,145
    Media:
    41
    47
    Mar 28, 2003
    Rick,
    That was me. I talked to Yukon and I asked the person if they had 4.56 ring and pinion, and complete 4.56 carriers (pumpkins). When I mentioned I had lockers he said no, then checked with someone else there and confirmed the no. I think others have said they knew of people running the Yukon 4.56's so now I don't know if the guy meant they did not have the locker/carriers complete or if they didn't have the ring and pinion either. He sounded like they did not have either.
    Bill
  8. landtank
    18,425
    601
    Mar 27, 2003
    Groveland MA
    The problem is with the reverse cut of the front gear. Older landcruisers that are part time have the same rotation front and rear. Not sure of the early FJ80s which way they are. Honestly for the price of a set of factory gears you can get 4.88s and a nice set of new 315s to go with them :G
  9. Beowulf
    Beowulf
    12,534
    30
    Mar 27, 2003
    Somewhere in the foothills...
    >> Not sure of the early FJ80s which way they are.  <<
    All US 80 series are FT 4WD, have 4.10 gears, and have reverse cut, high pinion, in the front.
    -B-
    (Edited to change 4.11 to 4.10)
  10. landtank
    18,425
    601
    Mar 27, 2003
    Groveland MA
    Well I've read that at least one person has 4.56s in his rig so they must be out there. Thought for sure they came from Randy's
  11. sleeoffroad
    sleeoffroad Supporting Vendor
    6,056
    531
    Mar 27, 2003
    Both 4.88's and 4.56's are available from Japan. Catch is, the shipping makes them very expensive, on top of a bad $/Yen and a not so cheap initial price.
    Randy's does have 4.88's and 4.5'6's as well. However I don't believe they have complete third members on a core exchange bases.
    Also, fwiw, Yukon is not a brand name. It is just a house brand from Randy's. It does not even mean the front and rear gears would be the same manufacturer.
    We do use the gears in the shop and have had good luck with them. However sometimes we reject some before we even install them. They have always been good at sending new sets to replace.
    The Toyota gears are machined much better, but it is difficult to convince people that they should spend 2-3 times as much on just the ring and pinion.
  12. landtank
    18,425
    601
    Mar 27, 2003
    Groveland MA
    From my experience with several european companies I beleive that the gears come from over there. Europeans write their 1s as a upside down cocked V. If you've seen this you'll know what I mean. Both sets that I recieved had serial numbers with this 1 in it. Probably more of a suspicion than anything I guess. I did have some slight harmonic vibrations when they first went in but that has worked it's way out.
  13. Junk
    Junk
    6,185
    23
    Dec 13, 2002
    buggerville nj
    I have Toy 4.56 in mine - from Christo - and would not go any other route. :urinate:
  14. Jim_Chow
    Jim_Chow
    2,479
    4
    Apr 28, 2003
    Turquoise Trail, N NM
  15. sleeoffroad
    6,056
    531
    Mar 27, 2003
    Those are v6 third members are not LC ones.
  16. Jim_Chow
    Jim_Chow
    2,479
    4
    Apr 28, 2003
    He also lists the reverse cut 8" diffs. V6 toyota trucks never came w/ solid axle front. Reverse cut gears weren't introduced until '96+, IIRC, and that's for IFS front diffs w/ 7.5" ring.
