Alright guy’s, I need some of your knowledge. I have been lurking on this forum since October 2015 and I’ve absorbed a ton of useful information. Thank you to everyone who has contributed to this site. It’s a great resource. I have a 1989 FJ62, 3FE engine. 190k miles. My issues started after the first day of “getting it”. It’s sputtering and dies like its being starved of fuel. But fuel pressure is within spec and the return pressure is fine. It will start up fine and warm up great. But then just goes to s*** the minute I apply any pedal, will sputter and then try to even itself out. Sometime it just straight dies. Odd thing is, it’s so intermittent. I suspect that the TPS may be an issue. The odd thing is, the first day I got it we took it on a 4 ½ hour drive to a place called crown king. No issues what so ever. Ran like a champ. Now issues ever since. NO ENGINE CODES WHATSOEVER
This is what I have done so far.
Checked fuel pressure came out ok but replaced Fuel pump, sock, FPR, FPD, and filter.
Cleaned out the fuel tank the best I could also cleaned the FP / sending unit connectors.
It had some junk and rust but not too much. Old pump and sock looked stock. Old sock wasn’t to plugged up but had some specs and hairs on it.
Replaced all hoses that connect to the tank. Minus the filler neck hose.
All vacuum lines have been gone through and replaced in the engine bay.
PVC and PVC grommet
AFM tested fine but I think still may be suspect (ohmed , have yet to do a voltage check)
Plugs replaced and timing is good.
So that leaves me to check the TPS. If that comes back fine I will be back to scratching my head.
I Know I may have answered my own question about the TPS or AFM but any other suggestions are welcome.
Does anyone know if the TPS or AFM from other Toyotas may be a direct swap? We have a great parts yard up here and I really don’t want to drop new prices for those parts.
Thanks in advance for your input.
AZFJGUY.
PVC and PVC grommet
AZFJGUY.
