3f in 1974 fj-40?
Discussion in '40- & 55-Series Tech' started by nccruiser, Jul 8, 2003.
  1. nccruiser
    nccruiser
    5
    Jun 3, 2002
    Does anyone know if a 3fe, auto tranny and t/c from a fj-62 can be installed into a '74 fj-40? How much longer is this drivetrain than '74 setup and what about motor/tran mounts? If anyone can help I would appreciate it!!!
    R.N.
  2. dd113
    dd113
    2,923
    1
    Jun 13, 2003
    Sure, it can be done. The A440F is about 1' longer than the 4 spd tranny. The TC is also a bit thicker so you will end up with a very short RR shaft but an almost normal FT shaft; perhaps a bit longer but not much. This will be a VERY involved conversion. You will need a pressurised tank with pump and a way to mount the ECU and wire it among a slew of other things. Personally, I see no need for EFI on my rock trucks but if you really want it go for the holley pro jection 500 and step it down to the 300 cfm that you need. Much easier and cheaper.
    If you want an auto tranny go to AA and see waht the best deal is on adaptors for US made trannys. The A440F is a great tranny but expensive and rare. Try to stick with a TOY split case.
  3. Bomar
    Bomar SILVER Star
    9,518
    2,093
    Jan 26, 2006
    Hot Springs, AR
    Wrong thread
  4. pappy
    pappy photosynthesizing Moderator
    7,933
    Media:
    78
    217
    Oct 7, 2003
    Palm trees and cool streams
    I was under the impression the A440F was significantly longer than a manual transmission. I would double check that before trying. Even a H55F with a split case is long leaving a short shaft (I think mine is 12").
  5. alaska60
    alaska60
    2,909
    13
    Apr 27, 2008
    Taos, New Mexico
    Why would you ever want to do this.....?
  6. Living in the Past
    Living in the Past SILVER Star
    11,989
    772
    Apr 21, 2005
    I own a FJ62 and like the power train. Still feels like a truck from that time period. Possible might do this myself but to a FJ45LP-B where length will not be a issue. Another problem not mentioned is you loose the hand brake with this setup. Adding the disc hand brake option will shorten a already too short rear drive line. I will go post 8/80 rear axle to solve this.
  7. YangFJ40
    YangFJ40
    126
    24
    Oct 8, 2014
    California
    I'm not sure with the tranny but if you were willing to keep the H42 why not just make a 2FE if of course you already have the 2F in there. Throw the head, intake, and use the wiring harness and distributor from the 3fe and slap it onto the 2F and call it done.
  8. cult45
    cult45
    2,675
    632
    Nov 30, 2011
    Brisneyland, Straya
    Because he can do whatever he likes?
  9. cult45
    cult45
    2,675
    632
    Nov 30, 2011
    Brisneyland, Straya
    Search for 'my boy blue', a fellow Mudder threw a 3F-E into his 40. Unsure trans though.
  10. hellbent40
    hellbent40
    1,062
    17
    Mar 3, 2006
    Victoria, B.C.
    most of the threads that i have read have stated that a 2f bell housing will bolt up to a 3fe.. so you can keep a h41 or h42
