39.5 on a fj40?
Discussion in '40- & 55-Series Tech' started by godzilla, Apr 28, 2003.
  1. godzilla
    godzilla
    254
    Apr 20, 2003
    What size wheel do I have to run with 39.5 boggers , what backspacing do I order, and will they hit the leaf springs. Has anybody done this before? I have a 71' fj40 with a soa lift and mini truck front hubs. Thanks
  2. woody
    woody Internet Fireman Staff Member
    10,329
    Media:
    303
    1,084
    Jan 15, 2002
    Toquerville UT
    3.5" backspacing is your minimum, but with that size tire I'd consider pushing it to 2 or 2.5" I run 2" BS on my Allieds with 14.5 wide SX's and like it.
    What width are the 39.5's? Most commonly, 10" rims are used for anthing up to 15.5/16.5 wide, but you could go to a 12" rim if you really wanted the added width.n My 14.5's are on 10" rims, ideally I'd have found a set of 9" rims.
    Section width x .66 = suggested offroaders rim width.
    15.5 x .66 = 10.23 ~ 10"
    14.5 x .66 = 9.57" ~ 10"
    12.5 x .66 = 8.25" ~ 8"
    10.5 x .66 = 6.93" ~ 7"
  3. CruisinGA
    CruisinGA
    6,163
    8
    Mar 27, 2003
    Georgia Tech
    Sorry to ask such a stupid question, but what exactly is backspacing, I know it has something to do with edge of wheel distance from centersection or the part of the wheel that bolts to the axle. I also know that 3.5" is ideal for most cruisers, but if that was "minimum" then wouldn't the number get larger instead of smaller? Just a quick little explanation would be nice, really appreciate it guys, this has baffled me and theres no one else I can ask. (None of my friends/family are much into wheeling) :-/
  4. woody
    10,329
    Media:
    303
    1,084
    Jan 15, 2002
    Toquerville UT
  5. SpaceGhost
    SpaceGhost
    467
    1
    Feb 1, 2002
    Indianapolis, Indiana
    I ran 38"s on my cruiser with leafs. 8" rims, 3.5" bs and yes they hit the springs. 2" of bs or maybe 10" rims and 3"s would have cleared. You can adjust the steering stops to avoid contact, but what fun is that? Oh and goodbye birfs.
  6. MD11Fr8Dog
    MD11Fr8Dog CM09 Eight Ball winner
    539
    4
    Apr 6, 2002
    Southern Pines, NC
    No such thing as a stupid Q!! Here ya go!!
    [​IMG]
  7. CruisinGA
    CruisinGA
    6,163
    8
    Mar 27, 2003
    Georgia Tech
    GREAT! :bow: JUST what I needed. That should go in the general Cruiser information page. So less backspacing equals wider footprint?
  8. MD11Fr8Dog
    539
    4
    Apr 6, 2002
    Southern Pines, NC
    Not exaclty footprint, as in tire footprint, but width of your stance increases and less rubbing issues on the insides of the tires
  9. cruiserhk91
    cruiserhk91
    8
    Jan 8, 2003
    backspacing won't be the issue here. using a stock width 40 axle you won't be able to turn full lock right or left with larger than 37" tires. the tires will hit the leaf spings. add about 6 to 8 inches to the width and you can run normal backspacing.
    running extreme offsets in the rim will increase the "scrub"
    while turning putting excessive loads on your steering components, perhaps to the point steering becomes impossible in very rough terrain
