350 tranny/clutch cover?
Discussion in '40- & 55-Series Tech' started by godzilla, Jul 17, 2003.
  1. godzilla
    godzilla
    254
    Apr 20, 2003
    I'm putting together my 350, sm465 and noticed that I'm missing the bottom cover plate to keep out the gook. Its the peice that fits on the lower half of the bellhousing. Whats this peice called, I've been to the local junkyard and all they do is scratch their heads(keep in mind, you hear banjos in the backround). Can I order this peice from a gm dealer or do I have to go the junkyard route? Thanks
  2. Niner
    Niner
    821
    Jun 4, 2002
    Readfield, WI
    You should be able to find one in the salvage yard. I call them a transmission flywheel cover. I also don't run one, because you would be amazed home much crap gets in there and won't come out.
  3. cruiserrg
    cruiserrg
    306
    Feb 11, 2002
    Mankato, MN
    ask for a clutch inspection cover, or for the rednecks- tin cover over the clutch.
