350 needs
Discussion in '40- & 55-Series Tech' started by BigRed87, Jul 20, 2003.
  1. BigRed87
    BigRed87
    269
    Jul 20, 2003
    THE Texas Tech U.
    I'm thinking that I might put a 350 into '87 fj60, but I am pretty clueless on what else I need to get to actually mount it and get it to run. I plan to run the Mark's adapter so I don't have to do any changes to the drive shafts, plus it comes with the motor mounts. Do I need to get all new alternator, PS pump, starter and the such, or can I use the ones I have on my stock 2F? Then what all little misc. parts will I need, I would also like to know how much some you guys that have done this before shelled out before everything was all said and done.
    Plus I get my BDS lift tomorrow and I can't get wait to get it on and order my 33" Geolander A/Ts. THANKS.
  2. hammerhead
    hammerhead
    1,995
    Jul 5, 2003
    Central, Utah
    With a chev motor you need a chev starter. I think on the rest its up to you.
  3. Gumby
    Gumby Supamod Staff Member s-Moderator
    11,778
    307
    Dec 13, 2002
    Knee deep in hookers and gin
    P/S and alternator will have to be chevy adapted to toyota wiring and hoses or toyota parts adapted through custom brackets to the chevy. Kinda 6 of one half-dozen of the other. sending units will need adapting. New exhaust. There's got to be more. It's a lot of work, but it's pretty much worth it, IMHO.
  4. fr8train
    fr8train
    100
    Jun 27, 2003
    Maryland
    OK going thru this fun now. Since I am also a chevy guy its really takes nothing to get these things out fitted. I dont know how much this affects you but, but here it goes. I have noticed that since I am putting a 383 TBI into my FJ40. I shortend the harness, added a 2wd steering pump and changed to the saginaw box for a jeep. All brackets can be had for any chevy motor in a junk yard. Got the custom hoses made at a race shop. Cooling had to be the hardest factor due to the limited space. Look up radiator.com they can help with a four core that will fit your desired dimensions. For my application the rear mounted battery is going to be a must. You may have an easier time. ON a side note. I am using a TBI so that means small cap distributor this helped me out with firewall clearance. And taht the only thing it helped out on so far. :D
  5. fr8train
    fr8train
    100
    Jun 27, 2003
    Maryland
    Oh yeah, using autometer gauges so sending units and what not are easier. Since its a fuel injection I had to custom make my tank so I just fabbed one from aluminum. All the lines are mixed hard and breaided stainless. Its just easier that way. ;)
