35"x14.5" Tires on 4" Lift?
Discussion in '40- & 55-Series Tech' started by 76Cruzr, May 30, 2003.
  1. 76Cruzr
    76Cruzr
    16
    May 6, 2003
    Anyone running this size tire with a 4" SUA lift, and if so did it require extended length shackles? The 4" Skyjacker lift is on order, but I want to replace the stock shackles as well. Just trying to figure out in advance if I will need extended length shackles or stock, and if I need ext. length shackles, what size.
    I'm already prepared to do some fender trimming.....
  2. rusmannx
    rusmannx
    1,159
    13
    Feb 9, 2002
    HIT IT!
    i'm only running 33's but i would guess you could do it. i would plan on that trimming. the only concern i have is that 14.5 might be to wide, and you may run into rubbing in tight turns.
  3. wayne_fj40
    wayne_fj40
    252
    Dec 31, 2002
    Yes I put 36" 14.5 swampers on and made some shackles that are about 3" higher then stock.But I'm just waiting for more money and aquiring enough crap to do a spring over good thing I'm in know big hurry :G
    Oh yea that does give me enough clearance
