3 speed transfer case shifter(s)?
Discussion in '40- & 55-Series Tech' started by pablo, Jun 29, 2003.
  1. pablo
    pablo
    83
    3
    Mar 5, 2002
    With the SM420 swap I am performing I considered a much easier way to accomplish the transfer case linkage. Instead of using the guide that directed the shifter from 2 to 4 to 4L in the OEM set-up, I was thinking of dual shifters that independently performed each function. I will have one for 2wd to 4wd and one for high to low. &nbsp:Does anyone see a mechanical issue with the transfer case shifting from high to low in 2 wheel drive?
    Thanks
    Pablo
  2. Degnol
    Degnol
    8,123
    Media:
    16
    6
    Jan 22, 2003
    Kansastitty
    This has been discussed here and on CCOT before, and the general consensus was that it should not hurt anything, in fact might come in handy if you were, say pulling a boat up a steep ramp on solid pavement and didn't want to engage 4WD but needed low range for pulling power.
    HTH :)
    Ed Long
  3. Degnol
    Degnol
    8,123
    Media:
    16
    6
    Jan 22, 2003
    Kansastitty
    Pablo,
    As a matter of fact, you can leave out the"gate" plate on the stock TC shifter and accomplish the same thing. The only precaution you need to take is, go easy on the gas pedal, because you can deliver a lot of torque to ONE diff, which can have some severe consequences for drivelines, u joints and axles. I don't know whether you are running a stock powerplant or a V8. The 420 already has a fairly low 1st gear.
    Ed
    P.S. No wheelstands! ;)
  4. pablo
    pablo
    83
    3
    Mar 5, 2002
    I was thinking more about getting out of a situation where the spining front is undesirable or the front 3rd is shot and you want to sleep in your bed.
    Pablo
  5. Degnol
    Degnol
    8,123
    Media:
    16
    6
    Jan 22, 2003
    Kansastitty
    Same laws of physics apply. Power normally split between 2 diffs now going to only one. Just don't break anything. My rig is a DD so I'm out of my league with wheelers. Sorry
    Ed
  6. CruisinGA
    CruisinGA
    6,163
    8
    Mar 27, 2003
    Georgia Tech
    TRe: 3 speed transfer case shifter(s)?
    This is why AA sells a twin stick adapter for LC, almost specifically for SMxxx tranny conversions, they adjust to any length, and make it easy for someone like me without the patience and fabbing skills to make their own linkage. ;)
  7. Pete_S
    Pete_S
    74
    Feb 3, 2003
    I've tried to find that on their site w/o any luck. Would you be so kind as to post a link for the twin stick?
  8. CruisinGA
    CruisinGA
    6,163
    8
    Mar 27, 2003
    Georgia Tech
  9. nspctr1
    nspctr1
    2,208
    2
    Jan 5, 2003
    San Antonio TX
    I think there is one for sale on Ebay and it's only 10 bux right now.
  10. CruisinGA
    CruisinGA
    6,163
    8
    Mar 27, 2003
    Georgia Tech
    Thanks for the heads up 8)
