2L-TE Valve shims
Discussion in 'Diesel Tech / 24 volts' started by buggyboy7, May 3, 2007.
  1. buggyboy7
    buggyboy7
    81
    Jun 24, 2006
    Courtenay BC
    Hi
    Does anyone have a collection or know where I can get valve shims for my 2LTE head?
    Thanks
  2. 2rivers
    2rivers
    316
    Dec 7, 2004
    BC, CANADA
    first off - you should know what numbers you need, and by that I mean you have to measure with a feeler gauge the thickness of each shim needed then look in the FSM at the range of thicknesses that correspond to your measurement(s) and write down those numbers ie. 2 #23's 1 #16 etc. Then you can order them piece by piece at toyota - they are not cheap though, but its not like you have many other options, and once setup you should be good to go for quite some time. I can look in my FSM if you need #'s.
    HTH
    Johnny
  3. buggyboy7
    buggyboy7
    81
    Jun 24, 2006
    Courtenay BC
    Shims
    Johnny
    I know the ones I need. 2 #16's and and one #45. I took one in to the Toyota dealer today and they said they don't have any like that (diameter wise)
    Have you bought them from a local Toyota dealer?
    Thanks
  4. light_duty
    light_duty
    425
    Oct 8, 2005
    in the stacks
    I got mine from 4 Wheel Auto in Edmonton. I think they were about $13 apiece.
    www.4wheelauto.ca
  5. buggyboy7
    buggyboy7
    81
    Jun 24, 2006
    Courtenay BC
    Valve shims
    Thanks Robin,
    I'll call Dan
