I recently acquired a very fun FJ40 with a '78 2F and (what I think is) the Downey TBI kit (w/ the GM computer from 4.3 engine). I drove it 600 miles and it did amazing, lots of power and I got 15 mpg on the highway maintaining 65-70mph with 37" tires, SOA etc. - highly exceeding my expectations (big hills of course mean going slower, but again, my expectations were low).
I've been driving it around for about a month, and now I do have a few things to figure out, and I was hoping you guys would have advice.
1) When it's cold, in the first couple of minutes, it idles pretty low (same as when hot) and sometimes dies. I live at 6000' and not sure if this has to do with it... but from my house I go up a hill, down the hill on the other side there is a stop sign at the bottom - every time I put it in neutral towards the stop sign at the end, the RPM's drop and the engine dies if I don't give it a blip on the throttle. Any idea what would cause this/how to fix it? Is there a temperature sensor that's perhaps not hooked up and it doesn't know the difference between cold and hot, so it's not giving it enough fuel when cold? Where would that sensor be located?
2) I get the occasional backfiring, it seems to happen when I'm under heavy acceleration and shifting from 3rd -> 4th. If I go over 3000rpm in 3rd gear, and I push the clutch in, it'll sometimes backfire (once). Any ideas why this happens? Or should I just live with it? (I do need to shift at 3000rpm due to a big gap between 3rd & 4th in the SM420..)
3) I was reading about the TBI setup here: http://www.tomquinn.com/lc/2f_fi/ - and it talks about someone having figured out the perfect PROM for the computer. I tried contacting the author and also the person behind http://www.olympiafj60.net/2f-tbi-carb-replacemnet.html but haven't had much luck getting in touch. I might already have a good setup so maybe I don't need to touch it (it was programmed by Turbo City who I understand are experts and sell their own TBI kit)...
4) I can't find the ALDL connector for the life of me (to hook up OBD I computer to read codes etc.) - any clues where someone would install it? Or perhaps it's not wired to the computer at all... I don't necessarily need to mess with it, but I want to be prepared to troubleshoot (I do have a check engine light wired on the dash).
Any other resources to recommend/read, apart from the two websites I listed in 3) above?
Thanks so much!
Thanks so much!
