78fj40mg
TLCA #23510
Ok a little update.
So we needed to remove the clutch housing to install the stand clamp onto the block. With not a lot of room on the ground below the block we had to use a high lift jack to tilt it back enough for me to be able to move clutch plate out to be able to reach the flywheel and housing bolts.
Went to collect the lift from boozewz but the thing was huge and couldn't fit In the RENAULT Kango which is a small van I took along.
So we ended up coming home empty handed.
That when the madness started. We started imaging a million and one ways to lift the engine onto the stand. From stretching tug ropes between two trucks and lifting it up, to using a PowerTank air lifter. All we need was to lift it about 20 inches.
In the end someone suggested a forklift. Luckily there is a construction site next to the house we sent for a fork lift.
Low and behold a forklift arrived and fixed what was a very difficult start to what seemed like a impossible job without a engine lift.
Positioned the engine and stand next to the gate so he could reach them.
Done
Im so excited. Now the real work can start.
Nice work!
You will need an engine hoist to get the engine back in the truck:
