I wanted to see if anybody has had a similar issue with their 2F:
My 2F recently had a valve job done, I've set the timing to 7 degrees BTDC, idle is at 650 rpm, mixture is correct, etc. It stumbles at 2000 RPM, no matter what gear I'm in. This only happens when my choke is off and the engine is warmed up. I can run 65+ on the highway with the choke pulled out, but once I push in the choke, it's like my engine loses 50% of its power.
-Possible root cause right now that I will check tonight is a broken BVSV, the lower one (pink, part # 90925-05046). I know that this operates the choke opener system, so I'm not sure that this is the source of the problem. This is being replaced tonight once the part comes in. If closing this vacuum leak fixes the issue, I'll let y'all know.
Any other suggestions? I read that the Hot Air Intake flap being closed could be the source of the problem, but I haven't verified that it's operating correctly yet.
Thanks,
-Hudson
1987 FJ60
Thanks,
-Hudson
1987 FJ60
