rkymtnflyfisher
Trout Bum
I have been troubleshooting my 40 for a few weeks now, what started as a nice warm day to go over my 40 turned into a bit of a debacle. I have an 83 2F engine, desmogged, non-us carb in my 74, I rebuilt this engine 5 years ago , less than 30K miles on it now. When I pulled my air cleaner to check the filter it was saturated with oil being pulled in from the valve cover, gunked up the carb, fouled the plugs, needless to say it had little power. I cleaned the carb the best I could while I figure out what else is the issue, new plugs, new air filter, runs like a beast now. I rerouted the valve cover temporarily, now a ton of smoke is blowing out of the hose I routed from the valve cover. With this smoke appears to be oil/water mix, chocolate milk dripping from the hose. If I plug the end of the hose with my thumb it build up a lot of pressure in the hose from the valve cover. Leads me to today. Pulled the valve cover, with the engine running there is smoke coming from the oil galley holes and the push rod holes, nothing from around the valves. Did a compression check, both wet and dry.
Dry #s-120-110-150-160-120-170
Wet #s-140-120-170-180-150-180
I also put 100 psi of air in each cylinder for about 10 minutes each, no hissing, no bubbles in the radiator, never leaked down according to my gauges on my air compressor.
Any suggestions before I pull the head to inspect the head gasket, and cylinders?
Could it be possible that I have a piston ring giving me an issue, letting gas/pressure blow by into the crankcase?
PCV valve seemed to be in good shape, there is strong vacuum on it, from the cover side to the intake manifold.
